My computer is infected and registry files - Computers & Internet
  • 407 Answers
Hi it may be virus scan your pc..........
if your lost registry file you load &download it to recovery it.....
load antivirus........
Posted on Mar 13, 2008
6ya staff
SOURCE:
How do I delete Weatherblink from my computer? I tried add/remove programs but even though it is listed add/remove says they cannot find the program.
If you perform a search via the start menu for the files associated with this program, any files renaming will show up there. You can delete each file when they come up and this should fully remove the program.
Aug 04, 2011 | weatherblink.com
I have a virus on my computer that none of my scans can seem to find. I have even done a system recovery to month ago and it is still here. I am in safe mode on my computer right now trying to find help....
The approach for a virus infection depends on what type of infection we are talking about. We need to know first the type of infection or what file is infecting the computer. Check the system configuration utility on your windows by typing msconfig on the run box. Check out the content of the startup and services tabs. Reseach on the entries on what are potentially infections running on your computer. Once you have found out the infection, try to search for entries in the registry editor. Type regedit on the run command. On the Registry editor, right click on computer and the choose search. Search for all entries of the found infection and delete them.
Note: Make sure that you create a restore point prior to deleting entries in the registry editor. One mistake here may make your computer unable to boot. But before creating a restore point, delete all current restore points by going to system properties. (right click on My Computer and choose properties) then on the system restore tab, un-check the box that says enable system restore then click on apply. Then put a check again then click apply. This should delete all previous restore points.
Jun 30, 2011 | Computers & Internet
W32.trojan.4492
Download SmitfraudFix:
Use this URL to download the latest version (the file contains both English and French versions):
http://siri.geekstogo.com/SmitfraudFix.exe
  • Search:
    • Double-click SmitfraudFix.exe
    • Select 1 and hit Enter to create a report of the infected files. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Clean:
    • Reboot your computer in Safe Mode (before the Windows icon appears, tap the F8 key continually)
    • Select 2 and hit Enter to delete infect files.
    • You will be prompted: Do you want to clean the registry ? answer Y (yes) and hit Enter in order to remove the Desktop background and clean registry keys associated with the infection.
    • The tool will now check if wininet.dll is infected. You may be prompted to replace the infected file (if found): Replace infected file ? answer Y (yes) and hit Enter to restore a clean file.
    • A reboot may be needed to finish the cleaning process. The report can be found at the root of the system drive, usually at C:\rapport.txt
  • Optional:
    • To restore Trusted and Restricted site zone, select 3 and hit Enter.
    • You will be prompted: Restore Trusted Zone ? answer Y (yes) and hit Enter to delete trusted zone.
Note:
process.exe is detected by some antivirus programs (AntiVir, Dr.Web, Kaspersky) as a "RiskTool". It is not a virus, but a program used to stop system processes. Antivirus programs cannot distinguish between "good" and "malicious" use of such programs, therefore they may alert the user.
http://www.beyondlogic.org/consulting/proc...processutil.htm
May 02, 2011 | Microsoft Windows XP Professional
Find driver easy tv captuer saa7130hl
http://download.cnet.com/Philips-SAA713X-Hybrid-Capture-Device/3000-2110_4-156884.html
if this does not help try www.driverdetective.org free to scan your computer if it finds your driver you will have to pay to download
I scaned file it looks clean but you should save it to your desktop and scan it also. G.L.
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database
version: 6326
Windows 6.1.7601 Service Pack 1
Internet Explorer 9.0.8112.16421
4/24/2011 2:14:55 PM
mbam-log-2011-04-24 (14-14-55).txt
Scan type: Quick scan
Objects scanned: 1
Time elapsed: 1 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Nortons insite scan
Scan Statistics:
Scan Time: 1 seconds
Scan Targets: C:\Desktop\Temp download\Drv_ATSC110_Philips_V1.3.3.2.zip
Counts:
Total items scanned: 78
- Files & Directories: 78
- Registry Entries: 0
- Processes & Start-up Items: 0
- Network & Browser Items: 0
- Other: 0
- Trusted Files: 1
- Skipped Files: 0
Total security risks detected: 0
Total items resolved: 0
Total items that require attention: 0
Resolved Threats:
No risks have been resolved
Unresolved Threats:
No unresolved risks
Apr 24, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Exe. files infected xp home edition can run[exe] any remedies
This problem occurs when one ore more of the following conditions are true:
  • The registry values that are associated with the file name extension are corrupted or the values are missing.
  • The computer is infected with a virus.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows To resolve this problem, follow these steps:
  1. Restart the problem computer in safe mode, and then back up the registry.
  2. Click Start, click Run, type command /c copy %Windir%\regedit.exe regedit.com, and then click OK.
  3. Click Start, click Run, type regedit, and then click OK.
  4. In Registry Editor, compare the following registry subkeys with the registry subkeys of a working computer for the file name extensions that do not open:
    • HKEY_CLASSES_ROOT\.<file_name_extension>
    • HKEY_CLASSES_ROOT\<file_name_extension>file
    • HKEY_CLASSES_ROOT\.<file_name_extension>\<Sub_Folder>
    If you cannot open the .com files, compare the following registry subkeys with the registry subkeys of the working computer:
    • HKEY_CLASSES_ROOT\.com
    • HKEY_CLASSES_ROOT\comfile
    • HKEY_CLASSES_ROOT\.com\PersistentHandler
  5. If you find any difference between the registry entries on the problem computer and on the working computer, restore the default values of the corrupted entries. To do this, follow these steps:
    1. Select the registry entry that you want to change.
    2. On the Edit menu, click Modify.
    3. In the Edit String dialog box, type the value that you find on the working computer in the Value data text box, and then click OK.
If the problem persists, follow these steps:
  1. Note the CLSID number that is found in the HKEY_CLASSES_ROOT\.com\PersistentHandler registry subkey.
    Note The CLSID consists of a long set of numbers that is enclosed in braces ({ }).
  2. Compare the CLSIDs with the CLSID that is located in the HKEY_CLASSES_ROOT\CLSID\<CLSID_number> registry subkey. If these CLSIDs differ, restore the default values of the corrupted entries.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 11, 2011 | Microsoft Windows XP Home Edition
Laptop logs off when i log on. what can i do
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer.
if it not work then go to back steps and just copy orwrite the file userinit.exe
Performing the above steps will resolve the issue.
Hope this helps.
Jul 07, 2010 | Dell Latitude D400 Notebook
Completing a recovery without a disk?
This is a common virus attack that will throw you out everytime you login, or licensing issues
For virus problem is bit tricky and needs to deal with registry settings and also need network computer
Try following
Run Regedit.exe
Edit below two values in right pane:
Shell
Userinit
Change the two values to
Shell=explorer.exe
Userinit = c:\windows\system32\userinit.exe
close the Registry
You should be able to log on to computer. if it not work then go to back steps and just copy and overwrite the file userinit.exe from installation source.
May 17, 2010 | E-Machines eMachines Desktop PC
How to remove virus without installing any virus removal software..
Format your disk and Reinstall operating system or find out which all are the infected registry and remove the virus registry contents manually.
or delete (hidden file) autorun.inf from all drives if it exists.
Dec 05, 2007 | Microsoft Windows XP Professional With...
Open Questions:
Amazon PrImE rEfUnD PhOnE [+1]845[481]1722 nUmber vviss AMAZON PRIME Tech Support Number +1-845-481-I722 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA Amazon Prime Technical SuPpOrT Number +1-845-481-I722 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 23, 2019 | Facebook Computers & Internet
Computers & Internet Logo
23 people viewed this question
Ekse
Marvin
Marvin
