Question about HP PhotoSmart 7350 InkJet Printer
I have an hp photoshop 7350 with an error message of "Print cartridge cradle is stuck". Can you help?
    Sergeant:
    Champion:
  • 297 Answers
Good day!Try to see if there is a foreign object that made it stucked..try cleaning the ink in the carrier of your cartridges..
feel free to ask..
mastergani
Posted on Mar 26, 2010
SOURCE:
Print cartridge cradle installation
how does the color catrigde for ip 1800 doing?
May 12, 2009 | Office Equipment & Supplies
I am getting a message that the print cartridge cradle is stuck. Where is the the cartiridge and how do i unstick it?
On HP's site at THIS LINK I found an article titled: "Resolving 'Print Cartridge is Stuck' Error Message". I hope this helps you. If you need any further help let me know.
Apr 09, 2009 | HP - HP Photosmart 8250 printer
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
Print cartridge cradle struck
packing material like spanch remove form printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Jun 15, 2007 | HP PhotoSmart 7960 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
277 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
