Question about LG Televison & Video
LG 42 inch HD LCD (42LB9F)
My LG 42 inch HD LCD (42LB9F) pictulates whenever I turn on another TV in the house (3 other TV's, 2 X CRT's and 1 X re-projection) the Antenna isn't amplified and the LCD losses single if any one of the TV's are in operation. LG Tech Support have said they have had report problems like this in multi dwelling and Multi TV situations and recommend the installation of a 10-12 dB attenuator on the LCD coaxial. I'm 35km from the transmittor and I not sure annenuating the signal is best, also the other TV's have good analouge pictures.
regards Andrew H
    Top Expert:
  • LG Master
  • 12,962 Answers
Try what they suggested. The attenuator may block some signal that is causing the difficulty with your set. And it is installed on only the line going to your set and not the main line coming into the house.
Posted on Apr 30, 2017
shadow5599
  • 51 Answers
SOURCE: 1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Posted on Oct 17, 2007
  • 2336 Answers
SOURCE: apex gb4308 43 inch projection tv
It looks like the convergency ICs failed on your TV. The IC numbers are STK 392-040, they are mounted on a big heatsink.
This may not be a DIY project, so I would suggest to take the TV to a repair shop.
Posted on Feb 18, 2008
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
  • 4234 Answers
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
SOURCE: Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Posted on Nov 07, 2008
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
42 inch LG LCD tv, mounted over a radiator?
electronics do not like heat and and heater works by rising hot air
in your case that hot air will go straight up into the electronics which will result in problems
a wide shelf under the tv will be a good idea as that will stop excess hot air straight up into the tv
Jul 26, 2017 | LG Electronics 42 in. LCD Tv
When I turn on my 61 inch, rear projection HDTV, a picture comes on for about 3 seconds before going off. The two LCD lights on the front of the T.V flash on and off. I hear the fans in the back of the TV...
very temper mental these things if it isn't the bulbs it could be one of the control boards that operates the pic and sound, but sometimes you have to keep messing around with the bulbs
Aug 03, 2011 | JVC HD-61Z575 61" Rear Projection...
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
TV freezes and now banging when turned on
Sounds like the problem is with channel 9. Is it an HD channel? Are you using cable, satelite or an antenna?
Apr 03, 2010 | LG 42LC2D 42 in. LCD HDTV
My 20 inch lg tv crt monitor will not show a
is video show on vcr player? if yes you need to replace jungle ic which is switching line from tv tuner to line in video.
Feb 10, 2010 | LG 42LC2D 42 in. LCD HDTV
42 inch LCD TV (one year old) won't turn on - the on button flashes
Contact LG for service. 1-800 243-0000
A capicitor on the main board has cracked causing the issue.
A simple fix.
Jan 19, 2010 | LG Electronics 42 in. LCD Tv
Televison & Video Logo
59 people viewed this question
