DVD screen wont work on LEgacy LD32MUB
I have A Legacy LD32MUB, this is my first time installing and using the device and the DVD screen will not show, nor will the settings button on the remote work to get into the settings screen. What do I do, thanks..
Read the owner manual more attentively please. There required to connect "brake wire" from the harness of radio to the "parking brake" - pedal sensor. or just coonect this wire to the ground wire or to the metal bolt of surface behind.
Posted on Sep 30, 2008
  • vanser85 Sep 30, 2008
    I did fixed my legacy LD32MUB like this after it sows everything video.
How can I fix the error I am receiving at initial start up? See details section for Error and description of what has already been done to try and fix.
It sounds like the hard drive in your machine has failed. It uses a standard 2.5" SATA hard drive (Most likely 9.5mm thickness maximum, most are that.) Hopefully you have made a recovery CD set from the recovery partition on the drive.
Feb 24, 2015 | Dell 15.6" Inspiron 15R Laptop Computer...
I have toshiba m45 and I have installed with windows 7. But many of driver can't installed inside.so I prefer to change with XP edition. I can't boot from USB drive. I want installed XP by using external...
Enter setup, set it to use legacy mode for USB devices, and move USB to before the HD so it's seen beforehand on the bot menu. F12 will sometimes let you choose the USB device to boot from, but Setup needs to see the device first.
Nov 27, 2017 | Toshiba Satellite M45-S355 (PSM40U073001)...
Im trying to hook up my subs to this headunit but i cant get the power from it to the amp. The amp is good and the subs are good
have you got a wiring kit for the amp? the amp needs atleast an 8 guage tho id suggest a 4 guage running from the batter to the amp with a 50 to 80 amp fuse atleast, then it needs to be ground to the chassis. a remote wire then needs to be run from the back of the headunit so that the amp only turns on when the ignition is on, then hook the wires from the amp to the sub.
Jun 23, 2010 | Legacy LD32MUB Car DVD Player
I can't get my computer to recognize my external USB device. I just installed a new harddrive and I'm trying to boot from a Vista OS DVD that is in my external USB device
when u power up the computer pressF2 or "del" key to enter in bios then set enable in USB 2.0 legacy then go to boot option and set first device as usb device .
Jul 14, 2009 | Office Equipment & Supplies
Labtop wont start up
check if u installed any new device recently. unplug all external cards like PCMCIA, USB drives, Memory cards and any USB device and try it again. if it continues, go to your bios settings and check your boot settings, make sure it boots from hard drive and not CD/DVD drive. if you have done any setting to the bios, revert it and try to start again. if it continues, check your keypads and buttons and make sure you don't have a sticky key or button that is pressed down. Cheers!
May 23, 2009 | Dell Inspiron 1525 Notebook
No picture
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 31, 2009 | Yamaha DVD-S540 DVD Player
LD32MUB bluetooth
The code for LD32MUB bluetooth is: "8888" - from owner's manual of LD32MUB
Oct 21, 2008 | RCA DRD480RE Receiver
Panasonic legacy connection
s-video is a legacy connection. legacy means obsolete and this will impare your image.
what you should do is connect the cable box and blue ray directly to tv with hdmi cable, then run audio cables back to the reciever from these devices. the vcr and regular dvd player would be routed through the reciever the conventional way. you would have to change the inputs on the tv between the cable box, and blue ray if u have one, and a seperate single tv imput for components running thru the stereo. you would have to use the reciever to select between audio sources, and the video sources between the vcr and dvd only.
Nov 04, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
57 people viewed this question
 Grubhead
Grubhead
