Question about Bazooka (EL10190PP) Car Audio Amplifier
ELA 500.I HI, WELL I JUST WANTED TO KNOW IF IS A GOOD IDEA FOR ME TO PURCHASE A BAZOOKA AMP IF I HAVE ONE 12´´ POWER REFERENCE MEMPHIS, CAN I GET ANOTHER BRAND THAT CAN DO A BETTER JOB??, OR IS THAT A GOOD CHOICEE?
    Sergeant:
  • 300 Answers
While I don't have any first-hand experience with either Bazooka amps or Memphis subs, this review pretty much says what I initial thoughts were. The amp will do the job without much fuss, so it mainly depends on whether you can get it for a good price.
BUT........
There could be a issue with your sub. According to Memphis, your sub (assuming it's the single voice coil version) is only good for about 250W RMS (let's ignore peak power for now). The ELA500.1, on the other hand, puts out 375W RMS at 4 ohms. You could very easily overpower your sub with that amp.
Posted on Mar 13, 2008
Trying to install a car audio to my low rider bicycle?
I build from mild to wild car audio systems. Give me an idea of what you are looking for? Is this on a trike or 2 wheeled lowrider?
Oct 20, 2011 | Bazooka EL1500 Car Audio Amplifier
Just wanted to know what the price on this item
if u can find one it shud range anywhere from 450 to 600.. internet like 450 500 retail more like 550 600.. i wud recomend JL or Memphis over an alphasonic any day if ur goin to spend that kind of money
Jan 12, 2010 | Alphasonik PMA1200D Car Audio Amplifier
I want bass that can pound
What kind of speakers are they? Liquid cooled speakers? I am assuming you are working with the bazooka speakers? Honest sugguestion: get different speakers. Bazooka is not that good of a brand. looking at bazooks's webiste the magnet size is only 30 ounces! The only good thing I have seen that have come out of bazooka was way back in the day their "P. Miller" series (a.k.a. Master P) And I never tested the subs, only the amp. What kind of car are you putting them in?
Next, a 4 channel amp is usually designated for the midrange/tweeter speakers. If you want good hard bass, only a mono or duel channel amp will put out the ohms that you need. Remember, you get what you pay for. If you get 20 dollar speakers and a 50 dollar amp, do NOT expect to hang with the big boys, even if the speaker is a 30 inch and the amp claims to be a 10,000 watt. Stay away from sony, stay away from bazooka, stay away from unknown brands.
My ideal set up would be Alpine type R or type X for subs, a Fosgate or memphis amp, and mb quart mid/tweeters. All are readily available, so competition keeps the prices affordable. Look at magnet weight when choosing subs.
Oct 01, 2009 | Car Audio & Video
Just wanted to know if memphis amp's r good amp's
hi, from what ive read,they seem to be rather good...have a quick look here,and see if this makes up your mind....
http://www.memphiscaraudio.com/products/power-reference/
Aug 16, 2009 | Car Audio & Video
I have a memphis amp that puts out 250 watts @ 4ohms and 500 watts @ 2 ohms. I want to hook up 3 sony 12'' explods @ 4 ohms a piece. How do I wire them to the amp to get the maximum output of 500 watts?...
well to be honest your amp probly cant handel 3 speakers because of the impedance levels so just hook up 2 bridges out to + to - on one Speaker then from that same speaker run + and - to the next one
A= amp
S= speakers
A:::::::::::::::::::::::::::::::S:::::::::::::::::::::::::::::S
Mar 22, 2009 | Car Audio & Video
I'm having problems getting full power to my sub.
you can only bridge it if your amp is made for it......the only other way is to have another of the same amp.......tell me what you come up with
Mar 05, 2009 | Bazooka 500-Watt Monoblock Amplifier...
No idea!!
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Sep 28, 2008 | Bazooka (EL10190PP) Car Audio Amplifier
Amp turns off after a couple minutes of playing
That's a new one on me.
The only electrical difference is the battery voltage on ACC is 12 volts. When you start the truck the alternator should put out about 13.7 volts. That would make me suspect a bad power supply in the amp or the output transistors, something in the amp is getting hot at the higher voltage and shutting it down
That would explain why you get two minutes ,and than when you turn the truck off the voltage drops back to 12 volts and the amp comes out of protect mode. Try a amp swap or if it's a self amplified tube, hook it up to a friends system.
Never hurts to put a voltmeter on the battery with the truck running, and off, to make sure the alternators voltage regulator
is not faulty and exceeding the rated voltage.
Good luck, let me know what happens, I'll ad it to the book.
Regards Paul
Jun 12, 2008 | Bazooka CSA150.1 Car Audio Amplifier
Bazooka (EL10190PP) Car Audio Amplifier Logo
123 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Abubacar Alfredo
Abubacar Alfredo
Level 1 Expert
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
