Question about Jenn-Air 36 in. CCG2523 Gas Cooktop
Creda 4 burner, converted to LP
What should the flame look like ?
my flame is blue, with yellow tips, only on the large burners...at high settings...
thanks
mikea1a
  • robert samples May 11, 2010
    what do the others look like and are they sooting
    President:
  • 2,976 Answers
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Posted on Jul 03, 2009
SOURCE:
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Bluestar rangetop clicks several times before igniting
Do other appliances in your home using LP gas work properly? If so, then this is probably an air/fuel mix problem on the burner(s). If this is a new rangetop there should be directions with the range and the LP conversion kit to instruct on proper adjustments. Be certain the correct LP orifice was installed for each burner (they likely have different BTU ratings for different sized burners) and the ignitor post is clean and spaced properly to burner. Then adjust the air mix to achieve a blue flame with just a tip of yellow. Delayed ignition usually results from the wrong air/gas mixture which doesn't ignite until too much fuel has accumulated. In many locations the company you purchase LP gas from will have someone who can check and adjust this. If the range was shipped from the factory as LP gas ready, then you can also contact your dealer and request assistance.
Feb 25, 2014 | BlueStar RGTNB364GHCSSLP 36" Pro-Style Gas...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
LPG question
hi my name is mark, lp will yellow tip alittle. check if your burners have air shutters some do some dont, they will be on the burner tube were the burner slips over the orifice. and should have a screw to keep them in place. loosen screw then carefully while the burner is lit open them some. be careful not to burn yourself, and careful not to open to far or you have problems getting them to light properly, and get popping on shut down of burners. hope this helped.
Mar 16, 2009 | Cooktops
Side burner on Jennaire grill
Hello
The soot stains come from the air mixture, that will show too much yellow flame tips, just adjust the air intake, too have an idea how much to adjust it, and also it wouldn't hurt to clean the flames holes by sticking a pin. Alos make sure you have the right fittings converters. It's the grill LP Gas or Natural?
Hope this help
Eddie Rentas
Tupper Lake NY
Aug 01, 2008 | DCS Double 30'' Grill Cart Side Burners in...
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Jenn-Air 36 in. CCG2523 Gas Cooktop Logo
317 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
MARLON KELLER
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
