Sony BRAVIA KDL-52X2000 50 in. HD-Ready LCD TV Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bulb is there anywhere too get a bulb for a sony bravia 50 inch tv without having too pay £170 or so
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Mar 26, 2010
Anonymous
Expert
Level 2:
Answers
308
Questions
0
Helped
134930
Points
814
You can try online but the chances of getting a counterfeit bulb are high. They don't last very long....
What causes my sony bravia dlp tv not to come on?
Sounds like it needs a new power supply board.
Here's one: http://www.shopjimmy.com/sony-a-1310-234-a-be-board.htm $69.32 USD
Easy to replace, just open the TV up, unplug and unscrew the old one, pop in the new one!
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
1helpful
Where can i find a replacement bulb for my 50 inch Sony bravia
Do a google search: 50" Sony Bravia bulb. Also there is a YouTube video on replacing the bulb correctly!. Good Luck
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
My 50 inch sony bravia screen cracked. how much is it to get repaired?
It can cost anywhere between £50 and $200 ($100 and £300) to get a 50 inch LCD TV fixed, if you have a Plasma TV, it'll be a bit more than that.
1helpful
2answers
New HDTV bulb
I have just bought a second hand Sony 50 inch Projection & the owner from new (paid 1200 Quid) assures me he has never replaced the bulb in 6 years. Don't pay 190 Pounds plus, if you can loosen 2 nuts you can get an Osram bulb alone (not mounted) for 32 Pounds 55 Dollars delivered if you search well on E Bay
4answers
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
2answers
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
