Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader staining..
I've been having problems now for almost a yr now with my whirlpool duet leaving greyish blue stains.. i've had the bearings replaced and yet the stains persist. i do not use fabric softner and very miminal purex he liquid
  • mtndogdev May 24, 2009
    I have  a light grey/brown staining problem as well, it seems to be on lights and whites any solutions or reasons
  • robert samples May 11, 2010
    are you using he detergent
Who replaced the bearings? mrdkirkham@aol.com
thanks
Posted on Apr 17, 2008
I had the same problem with my Duet front loader. Whirlpool parts has come up with a new cleaner made especially for front load washers. It's a tablet that cleans the inside of your washer.
Posted on Apr 07, 2008
I have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
Posted on Mar 15, 2008
Washer leaving stains in clothes
If you are using fabric softener, it could be the source of the stains
Oct 13, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
Whirlpool duet front load washer banging Loudly during spin cycle as if off balance
More than likely the washer tub bearing is worn out, this happens due to seal failure and soapy water getting into the bearing, the soap is very corrosive and the bearing fails quickly, this in turn destroys the drum vibration dampers and makes it much worse. The cost to repair this is about $400
Feb 13, 2012 | Whirlpool GHW9150 Duet Washer
Which is better for the dryer and why, dryer sheets or fabric softener in the wash?
Liquid in the washer is better since sheets in the dryer are prone to leaving stains (read back of package about stain warning on every box of softener sheets i have ever seen) also the sheets leave a build up on the thermostats and moisture sensor
While the liquid in the washer softens the clothes and has no build up or staining issues such as the sheets
Oct 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer and it is leaving brown streaks on my whites. What do you think is causing this problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oil Like Stains on dark cotton Clothes - Whirlpool duet
Problem Solved !!!
Ok, I had to stop and tell everyone about my latest experience. When we moved here we bought the nice Whirlpool front load washer and dryer set. I Love them....still don't understand how my clothes get clean with so little water, but love them. ..................That is until lately. I was really upset about a total of 4 white blouses that looked to have some kind of light splattered stains on them after washing. I would try to wash them again with a stain remover sprayed or scrubbed on the spots, but they wouldn't come clean. I gave up and considered the blouses ruined. I told William what was happening and he called the repair man out because he thought it might be some kind of part in the machine that was leaking oil onto the clothes when they were washing. The guy came out and told William that there wasn't anything that could go into the washer tub and get onto the clothes. He then looked around in the washer and at the little detergent dispenser drawer. He suggested that we use 1 cup of Clorox and 1/4 cup of dish washer detergent (cascade with dawn degreaser crystals) on a hot to medium water temperature and turn it on a complete wash cycle to make sure that we didn't have mold and mildew setting up in our machine. After he left, I proceeded to do what he told us. I though.....the blouses are probably ruined anyway. I had tried to get out all the spots to no avail, so what the heck......I threw them into the mix too! Would you believe they came out clean, very bright white (instead of yellowed or dingy from continued wear) and the washer smells as sweet as it did when it was new. Why didn't they tell me about this when I bought it ??????????? I plan on putting the detergent mix in the washer every couple of months and throwing in all the whites that I can find to take advantage of the cleaning effect on the whites. (I thought that maybe some of you had gotten stains on white clothes that you would like to get out too)
Dec 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
244 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
