Question about ASUS P5LD2 Motherboard
RAID issue I had a RAID5 drive failed on me and i replaced it. During the replacement a second drive failed and now i am stuck with one of the original drive working, the new drive which has not been rebuild and a second fail drive.
  • 35 Answers
So what is your problem then?
Posted on Mar 13, 2008
CISCO 6248 beep sound
Beep Codes Cause (Depending on RAID Level)
3 seconds on, 1 second off
  • RAID 0: One or more drives offline.
  • RAID 1: Two drives offline.
  • RAID 5: Two or more drives offline.
  • RAID 6: More than two drives offline
1 second on, 1 second off
  • RAID 1: A mirrored drive failed.
  • RAID 5: One drive failed.
  • RAID 6: One or two drives failed.
1 second on, 3 seconds off
A hot spare drive has completed the rebuild process and has been brought into the array.
Jul 24, 2014 | Cisco UCS 6248UP 48-Port Fabric...
I have got a 3 disk raid5 IBM xseries Server which does not boot. How can I resque data from these disks?
I'm going to go out on a limb and assume that you don't have a good backup of the data on your RAID array. So, generally speaking, the operating system is probably installed on a separate disk from your raid array (not a guarantee). But if this is so then you should be able to reinstall your operating system and drivers (esp RAID controller) to that (separate) disk and you're off to the races (replace this system disk if necessary). -OR- Depending on the make of your RAID controller you may be able to transplant your RAID controller into another machine and all the original drives along with it, so long as it has a battery backup and you place all the drives in their original order. If there is no battery backup on your RAID controller then DON'T PULL THE PLUG ON THE ORIGINAL MACHINE AND DON'T EVEN CONSIDER removing the RAID controller in any way. If you have any doubts, whatsoever, have someone with experience in RAID arrays do the work for you. It will be well worth it! (RAID arrays aren't for the faint of heart)...
Aug 24, 2011 | IBM eServer xSeries 225
Confuguring raid5
Hi
You would need 4 Hard disk drives in total. you would need to create 2 RAID 0 (striping) and then Mirror them (RAID 1). to elaborate, HDD A&B will be at RAID 0 as well as HDD C&D. after, you would have to Mirror your two RAID 0. (raid 0+1 is also known as raid 5)
Hope this helps.
Jul 09, 2010 | IBM x3400 Server
Can a raid5 be expanded to include an additional disk on the dac960prl or must the raid be destroyed and re-created?
As a rule of thumb, a raid 5 array can be expanded to include additional drives. This is done during the boot process and then going into your RAID controller setup. You would then go into the RAID configuration and add the new drive to the array. This was the simplified explanation but i think you get the idea.
Things to consider,
DO NOT remove the RAID array unless you dont care about losing data.
DO NOT try to add a smaller drive than what is currently part of the array.
When possible, the new drive should be identical to the existing drives, but I have added same size, same speed more than once and it will work.
All of the drives you want as part of the array must be on the same controller.
Hope this helps,
Brian
Jun 30, 2010 | LSI Logic Mylex AcceleRaid 150 DAC960PRL...
Data recovery
Unfortunately, a three disk RAID 5 can only tolerate a single drive failure. Is it possible that disk 0 and disk 1 were reversed? If so, then you might be dealing with only one failed drive and might be able to rebuild the RAID if you get disks back where they belong.
Otherwise, you will need to send the disks off to a data recovery service and hope for the best. This is only viable if the data is very valuable as this will be very expensive. Typically more than $1000 just to evaluate and diagnose.
Jul 09, 2009 | IBM eServer xSeries 225
RAID5 SCSI HDD
YOU WILL NEED TO UPGRADE THE FIRMWARE ON THE OLDER DRIVES
Dec 25, 2008 | Seagate (s40a102) 146 GB Hard Drive
Re-Synching problem with RAID5 Arrays in windows 2003 server
I beleave RAID5 needs all 3 disks to be present and maybe even on the same channels as they where set up for really id depends on the capability of your software or hard card. Good Luck!
Thank you,
Rel
May 21, 2008 | Microsoft Windows Server Standard 2003 for...
Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Jan 26, 2008 | HP Compaq ProLiant DL380 G4 Server
ASUS P5LD2 Motherboard Logo
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
