I need drive for MTP PLAYER - Audio Players & Recorders
  • 1 more comment
  • shafi08 Mar 13, 2008
    IPOD WORKING DO ON THE SPOT OFF
  • Anonymous May 07, 2008
    gpx mw3836 mp3 player
  • pretsell May 17, 2008
    plug in needs MTP pluggin or something
This mario my mp4/ gpx mtp device do want me to put videos on there how do i do that
Posted on Oct 02, 2008
I need Too!!
Posted on Jan 26, 2009
Computer doesnt show video,slide show, says it downloading but isnt on unit when restarted
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa e250 MP3 Player
Tip
Solve your MP3 Player Connection Problem.
  • Turn the player on, if it is not already
  • Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc...
  • Navigate to "Settings" on the main menu of the player.
  • After navigating to "Settings", you should see an option that states "USB" or "USB MODE"
  • From here we can select MSC or MTP modes (could vary based on player model)
  • Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu
  • Connect the player to your computer and verify it is connecting in the desired mode.
on Jan 01, 2010 | Audio Players & Recorders
My MP3 stopped working. It doesn't need to be
Feb 13, 2010 | SanDisk Sansa Clip MP3 Player
I HAVE SYNCHED THE MUSIC BUT ONLY THE SONGS THAT WERE ALREADEY ON WILL PLAY
Feb 13, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
A service section installation INF is invalid.
Just to be clear, no special drives are necessary. MSC mode will work out of the box with just about any OS. MTP mode will work as long as you have WMP 10 or 11 installedFirstly, lets explain MSC mode and MTP mode a bit.
MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a flash drive, as a removable disk. It will assign it the first available drive letter, as well as one for the memory card (if applicable). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most comptuers detect the player in this mode without a problem.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsofts solution to connecting digital players and cameras to a window based platform. MTP mode must be used in order to transfer ANY Digital Rights Managment (DRM) protected content. Services like Rhapsody and Napster will only function in this MTP mode.
SanDisk has provided both of these modes at the users options on MOST of the entire Sansa Line mp3 players. The c200, and The View, do not have these 2 options in every version of firmware. Instead those players use an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
Switching between MSC and MTP modes
  • Turn the Sansa on, if it is not already
  • Navigate to the main menu of the player; this is the same menu that gives us options such as Play, Record, Info, etc...
  • After navigating to "Settings", we should see an option that states "USB" or "USB MODE"
  • Connect the player to the computer and verify it is connecting in the desired mode.
You can also try to reinstall Windows Media Player 10 or 11. Next W*ndows has a update to fix if all else fails try this. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Jan 01, 2010 | SanDisk Sansa MP3 Player
I lost my cd and need to reinstall the driver and software
Sorry but there are no specific drivers on the CD for this player. I've had this player since '05 and was trying to get it installed under Windows Vista with only limited success. This player seems to work best with Win XP.
The c150 has two modes of operation MSC and MTP. In MSC mode Windows recognizes the player as a flash drive. You create folders using Windows Explorer just like you do on any hard drive and then copy your music files into the folders. The second mode (MTP) works with a music player such as Rhapsody or Windows Media Player (ver. 10 or higher). SanDisk bundled Rhapsody on their CD and I just installed it (today) on my Vista PC and it seems to work OK. Any files dropped on the player in MTP mode are invisible to the music player running in MSC mode. However, all files added to the player, regardless of the mode used, are visible as one big happy list when you use the player.
You set the mode you want to use before plugging the player into a USB port by going to "menu/settings/USB" on the player then choose either MSC or Auto Detect (defaults to MTP).
SanDisk has very little tech support info about this player on it's web site. I hope this is helpful.
Jul 12, 2009 | SanDisk Sansa c150 MP3 Player
PC does not recognize ML648B in USB Mode
Switch the Player to MTP Mode instead.
• The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive.
• In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive. This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced.
• The difference with media files, specifically music files, is that they demand much more management.
• Downloading services can require special licensing and a limit on the number of playbacks a music file can have.
• The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
• For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP.
• Those with Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center.
• We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the power button on your device once it’s connected to the computer until the USB icon disappears.
Jan 27, 2009 | GPX ML648B MP3 Player
Mtp
  • The USB mode uses a file transfer class called the MSC (Mass Storage Class). This was developed as a way for files to be transferred onto an external drive such as a flash drive or an external hard drive. In this mode, your mp3 player will look and function like an external hard drive in that it will appear in My Computer as a separate drive.
  • This transfer class is not very specific to the transfer of media files so the MTP (Media Transfer Protocol) was introduced. The difference with media files, specifically music files, is that they demand much more management. Downloading services can require special licensing and a limit on the number of playbacks a music file can have. The acquisition, restoration, updating, and backing up of these licenses as well as compatibility issues with file type and compression ratio within these digital music players demanded a more user-friendly and functional approach to file transfers.
  • For this reason, you will need to have Windows Media Player 10 or 11 available on your computer to utilize MTP. Those who have Windows Media Player 9 on their Windows 98 SE, Windows Millennium Edition, and Windows 2000 operating system will need to update using our Download Center. We recommend the use of MTP over MSC (the USB mode on your player) because it is more specific to the transfer of music files. To change this setting, press the button on the top of your player marked M
  • -Tha Mp3 Doctor
    Oct 29, 2008 | GPX MW3836 MP3 Player
    Ilo 1GB 3.101.103 MP3 Player = MTP Device?
    Uninstall MTP Device in System --> Hardware --> Device Manager
    May 18, 2008 | iLO MP3 Player
    Sansa mp3 player
    If the player is in MTP/Autodetect you can just unplug the player from the computer. You can check this by going to the My Computer window and see if the player is listed and if it has a drive letter before it, if it dont have a drive letter then it means the player is in MTP/Autodetect you can just unplug the player from the computer.
    Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
    394 people viewed this question
     Grubhead
    Grubhead
