Question about Insignia NS-PDVD8 Portable DVD Player
Turning on the second i turn my dvd player on, it flashes the blue insignia screen and shuts off with the disk still spinning
  • beachgirlo Oct 10, 2008
    Your solution worked great.....thank you, would have never solved it without your help.......
I second quavuama. I had the same symptoms after my four-year-old "broke" it. He actually figured it out and suggested the fix. He said "Daddy, the little button is stuck..." OK, yeah right, I said. But he pointed to the small auto shut-off button just above the source and setup buttons. When the lid closes the button is pushed down and off goes the picture. Well little four-year-old fingers was fingering the button and it got stuck in the down position. I used a sharp tip to work it back to the "sprung" position. Picture now comes on.
Posted on Jun 10, 2008
Look to the bottom right of the screen. on the console there is this plastic finger thingy. it sticks out to push a button on the bottom portion of the player. when you close the book the button pushes the button and turns off the screen, when the book is closed there is no need for the screen to be on. the button is designed like the old washing machines, the kind that stop agitating when the door is open, same principle. chech the button that the plastic finger pushes, it may be stuck. if it is use a strong needle to finagle the button free.
Posted on Apr 08, 2008
Same problem with switch, SnapShotCapeMay.com
thanks
Posted on Oct 18, 2008
  • Sasha Lavender
    Sasha Lavender Dec 26, 2013
    OMG! Thank you for this. I though a Christmas present was broken until I read this.
SOURCE:
It had a smell like something was burning. Now when you turn it on we only see a white screen. This is an Insignia Portable 7 inch dvd player NS-SKPDVD. It sounds like it is spinning for a second and then...
The main PCB board have burn parts,take it aparts and check it by ur self.Replaced parts by ur self.If u want it to repair by the shop don't,not worth repairing.U can get new one pretty cheap.
Jun 18, 2010 | Insignia NS-7PDVD
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
Tv Screen Turns blue occassionally while running Toshiba DVD player
If the flashing is regardless of source, the CRT could be at fault. H to K short. ( heater to cathode)
Jul 23, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Insignia IS-PD04922 Poratble DVD Player 2005
take a cotton swab with some alchohol on it and clean the lens, let it dry and try again.
Jun 09, 2008 | Insignia I-PD720 Portable DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
My insigna I-dp720 won't play dvds
My Insignia DVD player says that there is no disc in the player, although it's in there... What can I do?
Thanks. S.
Jan 06, 2008 | Insignia I-PD720 Portable DVD Player
Message 0
Sorry, I don't have solution. I have exactly the same problem with my Insignia. I have tried everything. It worked fine for 18 mos. I am thinking I need to discard it. Shoot. If you get an answer let me know Thank You
Jul 25, 2007 | Insignia IS-HC04091
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia NS-PDVD8 Portable DVD Player Logo
262 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
