Question about Nintendo Wii Console
Sensor bar doesn't work
Is there a quick fix on the sensor bar without getting a new one. I have no lights on the bar.
    Problem Solver:
  • 16 Answers
First check with a cellphone camera or digital camer that the sensor bar is working, with the wii ON look at the sensor bar through the camera, if it is working you should see some bright dots at each end of the sensor bar.
If it is not working, turn off wii, check connections ie, unplug and re plug the sensor bar jack.
Turn on wii and use the camera again.
If it still does not work, check wire that leads to sensor bar for damage, if it is damaged you can cut it and solder the wires back again, taking away the damaged part off course, just be wary that you connect the cables (2) with the same color again, or if you have on that has same colored wires just cut one at a time and mark them with a pen so you can distinguish one from the other. Then soler them back together and try again.
Good luck
Posted on Oct 07, 2008
  • Hugo Hugosson Oct 12, 2008
    Also if that does not help make your own sensor abr, if you know how to solder and have some basic componet knowledge, if you don´t maybe someone you know can help you.
    Anyway here´s a schematic on the sensor bar.
    Remember that it DOES NOT have to be connected to the wii, The only thing that the connection to the wii is feed the sensor bar with voltage.
  • 53 Answers
1) Is the bar plugged into the console?
2) Did your cat or dog chew through the wire?
3) Have you tried using the setup menu to alter the remote's sensitivity?
4) Is anything interfering with the sensor bar, such as a reflective surface or other lighting in the room? Shiny coffeetable tops and fluorescent lights aren't friendly to the Wiimote. Try covering reflective surfaces and playing with the lights off.
5) If you get a replacement and still have the same problem, then the problem is with the Wiimote.
Posted on Mar 24, 2008
Brake stop light stays on had it in da shop but did not fix da problem
{: ) Did somebody worked on the BCM or your brake pedal? The wirings and connectors could have been knocked off. For the moment. let's just rule out the wiring issue first.
Under normal operations, the stop lamps get its power from the BCM (body control module). The BCM monitors the signals coming from the brake pedal sensor whenever you step on the brakes or not.
The component fix is to replace the brake pedal position sensor. I just hope your problem doesn't come to the point of replacing the BCM too (rarely happens).
But before proceeding with the replacement options, try to bring it to a shop with a GM scan tool and ask them to perform the brake pedal position sensor calibration. This is the quick fix without replacing any component. I hope you get lucky.
Jul 03, 2011 | 2006 Chevrolet Malibu
Cannot get curser to show on screen
This could very possibly be an issue with the sensor bar. Try these steps:
  1. First, ensure your sensor bar is plugged into the console and oriented properly! Take a look at this picture to see how it's supposed to be facing (NOTE: you will NOT see the purple lights even if your sensor bar is working!! These are ultraviolet lights and are not detectable to the human eye!) Click here for the picture.
  2. Make sure your Wii remote is on and has new batteries! Older batteries decrease the strength of the light that the Wii remote gives off that it uses to communicate with your sensor bar.
  3. Assuming these things work, consider increasing the sensitivity of your sensor bar. Directions for how to do this have been posted online by Nintendo here.
If none of this works, chances are there's something wrong with your sensor bar, Wii remote, or a combination of both. Replace the sensor bar before replacing anything else. If that doesn't work, get a new Wii remote. Good luck!
Mar 12, 2011 | Nintendo Wii Console
Brand new wii sensor bar not working . sensor lites up , game comes on , but "pointers" wont appear on screen ? any solutions ?i
There are a few possibilities:
  • Light/Heat sources interfering with the sensor.
  • Ensure the bar is oriented correctly
  • Ensure the Wiimote is properly synced
  • Ensure the sensor bar sensitivity is set correctly.
  • Not all games use pointers, but work regardless
If all else fails, turn off the console for five minutes.
This will reset the console and possibly fix your problem.
Mar 06, 2011 | Nintendo Wii Console
I have a nyko wireless wii sensor bar. the first one I had would not turn on, and so I got a new one but the same problem is happening. the blue light will not turn on.
First thing to check is your battery... This sensor bar is nice that it doesn't require a wire for power, but the battery tends to drain pretty quickly. After about 8-hours or so of playtime you'll probably have to change batteries.
You also need to calibrate the sensitivity if your Wiimote afterwards to make sure it works properly.
Lastly, this bar is also known to have issues with some third party controllers. If you're not using the official Wiimote you might also have issue with this bar.
May 27, 2010 | Nyko Wireless Sensor Bar for Nintendo Wii
Why does the Wii sensor bar only work with candles near it? It even works without the sensor bar plugged in - candles only.
The sensor for the Wii-mote is actually heat sensitive, so it is not the sensor bar at all, it's the heat. You need a new sensor bar.
Dec 19, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Nintendo wii,can't get past selection menu for language
First make sure you sensor bar is plugged into your wii correctly, and it is centered and on the top of your TV.
If you still have the problem then you need to sync your remote with the wii. Do this by holding down the red sync button on the remote, located under the battery cover on the back, while holding down the red sync button on the wii, located next to the SD Card slot.
If it still doesn't work, that means you have a bad sensor bar, you can get a new one at wal-mart for $20. To make sure that it is not the sensor bar, take a video camera and take a quick video of your sensor bar while it is plugged in and the wii is on. In the video, if you see five LED lights on both sides of the bar than it is fine.
Hope this helps!
Dec 25, 2008 | Nintendo Wii Console
4 remotes stopped working
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 02, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
528 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
