Question about HP Compaq dx2000 Microtower PC Desktop
My computer will not start up
The system will not boot at all. there are no beeps.
The only thing the computer does is flash the orange light once, thats it.
whats wrong?
  • osose32 Mar 13, 2008
    what should i check on it?
    do i need to take it to the technician to swap out?
    what causes power supply units to give out?
    what battery are you talkin bout? this is a desktop
Check the battery power, with adapter.
Posted on Mar 13, 2008
  • 75 Answers
Try to check the PSU of your Pc.
  • Marc Cuyag Mar 13, 2008
    if you have a spare PSU u can do it and change the PSU of your pc, just compare all the socket in psu,
    if you not familiar with that work maybe you need a technician to look your PC problem.
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Will NOT start up, or switch on. battery and or Mains power green lights blink orange./ yellow. been doing it for months, so I do not turn it off, seems to run ok once it is going, but it is slow, had a...
    Hello and thank you for using Fixya's services.
    I have a couple of questions and some troubleshooting tips for you:
    Questions: Is the splash screen coming on at all? Any picture or text right when you boot up? What Windows are you running (Windows XP or Vista)? Are there any lights on when you boot up or beeps? If so how many beeps do you hear?
    First troubleshooting: If it boots up and is at least showing the splash screen (splash screen or text) then it would be that the operating system is corrupt. This can be caused by several things included viruses, power surges or hardware failure.
    The solution for this would be to take the hard drive out and slave it to another working desktop computer to retrieve your data. The attach the hard drive back on and reformat it (I can add specifics to doing this once I know the operating system).
    Second troubleshooting: If you hear the operating system chime but do not see a picture and all the lights are on, then this would indicate that the back light on the screen is out. You can test this simply by hooking the laptop up to a monitor and see if you get a picture. If the computer screen shows on the monitor, then your back-light is out. If it doesn't show up then your video graphics card is out.
    If the back light is out, it is easier to order a new screen (new or used) from eBay and just switch out (simple process and you can find a replacement for under 50 dollars on eBay). If it is the video graphics card, then you can also purchase one from eBay and switch out (a little tougher because you have to take the top of the laptop off). You can get assistance with this from the manufacturers website and pull specs for free.
    Third troubleshooting: If you do not hear any beeps and the above solutions did not work. Then your motherboard has failed. This can be caused by surges or dust. You can purchase a replacement from eBay for a fraction of the cost and replace (this is tough and I am not sure if they have specs for this). You can do it yourself, just be sure and put everything back together as it was.
    Fourth troubleshooting: To test the battery, take the battery out of the laptop and turn on with just the adaptor. If it boots, then the battery will need to be replaced. There is no way of testing the power adaptor but 85% of the time, this is the problem. Even if lights come on, the adaptor sometimes gets so overheated that it silently goes out but gives just enough power to make the lights come on. The power adaptor can be found on eBay for under 20 dollars and is cheap enough to replace (first) to make sure that is not the problem. The battery can also be found on eBay for under 60 dollars.
    Please let me know if you have any questions and I will be glad to assist.
    Nov 05, 2009 | Computers & Internet
    Samsung V25. When i try to turn it on nothing happens. Even when it is plugged into the mains the little light is orange then when i try to turn it on both lights go green, then one goes off straight away...
    hi
    this kind of problem can be because of two things
    harware or software in the operating system .
    first try to check that when you start the laptop is it giving you any beep sound if it not giving you any kind of sound then their is hardware
    if it gives the beep then try to try to boot the computer from a cd and it will definetly work ..
    or else you can contact me on fixya
    Jul 22, 2009 | Samsung V25 XVC 2800 Notebook
    Help with server boot problems flashing orange lights etc
    Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
    If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
    Not sure what RAID you are using or how many drives, so feel free to explain more.
    G'luck
    Oct 24, 2008 | Dell PowerEdge 4600 Server
    Wont Boot Power Light Flashing orange
    onbord video maby might wann add pci card video see if u get screen ok thx nick
    Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
    No screen, no boot, only the power LED flash orange
    In this case you should examine the motherboard and the processor.
    verify the Mboard maybe maybe some part oversheat, if non then , Kindly remove the processor, then switch on for a while then shutdown: fix back the procesor and then switch on. still no beeps? try your Processor to other computer system with same socket on mainboard. if the processr work; then your mainboard is damage. u need to replace; if not work. processor is damage and need to replace.
    Be sure to test all the pheriperals of your system before you buy a replacement to see if some other parts is no problem.
    Like memory, VGA,
    If all of the solution is not working its time u to assemble new computer system. i give you all the possible solution, or else tell me the working part i will help you seeking and speicy the replacemnet part.
    thank you more power.
    Jan 29, 2008 | Acer Aspire 3680 Laptop
    HP Compaq dx2000 Microtower PC Desktop Logo
    253 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
