Water leak Water is leaking from the siphon break, how can I prevent this?
  • Jan_H Mar 16, 2008
    I took the siphon break out and cleaned the lime scale, or whatever the white stuff was, with Lime Away, and soaked it overnight. It solved the problem.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Leaking fromsiphon break is usuallya sign of a restricted drain assy.def check your drain for cloggs, sounds like magor back pressure to leak there
Posted on Mar 13, 2008
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
Leaking from under front of machine
Hello there
Please read the entire solution to best match your problem I have provided below
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
I will post the rest of the solution in the next comment
Dec 26, 2010 | Kenmore 24032\24036 Top Load Washer
Water leaks under machine when filling
Hello, if your washer leaks only when filling then you have to check these:
Air-gap device- The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
THE TUBE - There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak
inlet spout- Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tube. If the spout cracks or breaks free of it's mounting, it can cause a leak.
Thanks
Jun 04, 2010 | Danby DWM99W Top Load Washer
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
May 26, 2010 | Whirlpool Washing Machines
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Hand held shower head leaking where connected to bracket
If it leaks continuously during use, verify that a rubber washer was used in that connection and that the connection is tight.
If it only leaks after the water is shut-off, there is a vacuum breaker installed there, which prevents water from siphoning back into your water system. It is normal for water to drain at this connection when the water is shut off.
Jan 25, 2010 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Water is leaking out from the bottom
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine leaks water as tank is filling up.
Hi
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Kenmore Washing Machines
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    Leaking when wash starts
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Washing Machines Logo
    90 people viewed this question
    Top Washing Machines Experts
