Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Viewsat ultra 2000 setup issues
I have a new set up used dish 500 with dual lnb ports 1 and 2 and I can only get sat 110 and no 119. my sat lnb freq 11250 tp 12224 discq port4 legacy sw dish 1 sw42 for 119 settings. I hope you can help please advise! thanks
  • Anonymous Feb 06, 2009
    I have viewsat ultra lite n i bought a DISHpro [PLUS ] i cannot get any 61.5 channel or any 119 ! i conected it w.o. any Diseqc! how do i set it up please help!!!
Go to fta bins.net for your solution
Posted on Oct 17, 2008
  • 2,336 Answers
You can go HERE to get all the info on how to set up your dish.
Posted on Mar 13, 2008
Error 771
ok explain a little more please. Make sure U have the coax coming from the Dish (outside) going into the back of receiver where it says SAT in. or if it is a dual tuner (ie: 322 etc) make sure the coax in hooked up to the Separator. also make sure u are using the correct dish and lnb to match ur receiver. I ALWAYS do a "check switch: every time I hook up to a new/different dish just to make sure the receiver recognizes the LNB.
Sep 02, 2014 | Directv D10 DTV Receiver
Dish 625 with legacy lnb
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Mar 31, 2012 | DISH Network DVR-625 DTV Receiver /...
Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Jan 16, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
I have a viewsat ultra. It will turn on.. but if I have the cable from sat in the back of the receiver,.. where it should be in sat in.. it wont turn on... but without my cable from the dish itself it will...
If you are using a switch between the viewsat and the LNB, remove it and connect the receiver again.
If that did not work, remove the cable from the LNB and power up again; if the receiver still unable to power up then you might have a short circuit in the cable itself or water might be entrapped inside the connectors on the LNB/switch connections.
Let me know if you need further assistance.
Jan 08, 2009 | Yamaha HTR-5730 Receiver
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
Viewsat ultra update doesn't help
You need to reaim your dish to echo 110 .You have it on bell and bell is down.Try reaim then factory set then rescan and make sure you have the right tp and freq settings freq is 12250 and tp is 12258 then autoscan exit when done and let it sit for 15 min on channel 500 cnn and it should work hope i gave you a fixya thanks :)
Oct 04, 2008 | Yamaha HTR-5730 Receiver
Viewsat Ultra 2000 missing spike channels
join a fta forum. You will find a lot of info. You need to do a sat scan
good luck!
Oct 03, 2008 | Yamaha HTR-5730 Receiver
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
Re-Program ?
restart you computer. repeatedly press f8.
go to safe mode.
have a system restore.
Jan 27, 2008 | New Product Innovations NPI NPI NUWAVE...
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
550 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
