Question about Kenmore 80412 Microwave Oven
Heating I have a kenmore mode # 564 8888611. The light and fan are both working when it is running but nothing will heat.
  • 2,326 Answers
If the microwave is working but not heating 9 of 10 times is the magnetron that fails.
Check this site for more info on the subject, you can also find that part in one of their sponsors.
Good Luck.
Posted on Mar 13, 2008
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
Does not heat anymore, power is going to unit, the clock, and fan work, light still works but it will not heat and makes a low growling sound when we try to run it. Help!
What you are describing is a problem with the magnetron and it has become faulty, that is the main part that heats the food, the growling sound indicates it is loading down the power transformer that energizes the magnetron. The repair cost will not justify the expense "costly" replacement of the microwave oven "cheaper" in the long run.
Jan 21, 2011 | Kenmore 80412 Microwave Oven
I have a GE SpacesaverXL model JVM1350BW. It does not heat up. The interior light, surface light, fan, clock, keypad all work normally. When a cooking mode is chosen and START is pressed there is a...
I wouldn't worry about the sensor error right away.
Sometimes that's just caused when the door is opened before steam could be detected or steam was not detected in the maximum amount of time.
Once it's all working again, if you still get the error regularly, it may be a bad humidity sensor.
If the internal cooling fan IS running when you try to cook AND the oven is not heating, it's probably a failed secondary interlock relay on the control circuit board.
If the internal cooling fan is NOT running when you try to cook AND it's not heating, the bottom door switch is probably the culprit.
Here's is a file on checking and replacing door switches.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Listen to that very carefully, and listen to yours to see if the cooling fan is working.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let me know if I can help you further.
Aug 22, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Kenmore 80412 Microwave Oven Logo
106 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
