Question about Philips 60P8342 60" Rear Projection Television
64p8342 Powers up,but no picture.
I have a Philips 64p8342 televisions that powers up, but no picture is shown on screen. Please help with any info.
  • Philips Master
  • 8,617 Answers
Try resoldering the vertical output IC have seen many of this model have hairline cracks on the vertical IC solder joints causing blanking of the CRTs while audio still worked.
Posted on Mar 13, 2008
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
How can i fix my Philips model 42PFL5432D/37 Flat screen TV that powers on, but no picture.
The main board to your TV is faulty. It is best to contact the authorized service center for Philips; because, it will be very difficult to get the main board to Philips brand TVs, and after the replacement, a firmware update too will be necessary. This is a skilled work. http://electronicshelponline.blogspot.com/
Jul 27, 2015 | Philips Televison & Video
Philips TV troubleshooting
Sounds like a main board fault. Please contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 05, 2014 | Televison & Video
Rca tv/dvd combo L32HD32D powers on and for 2 seconds shows, Please Wait, on the screen then goes black. What do i do?
After the screen goes black, do you still have sound or you have none but a blank screen? If you have no picture and sound does the power LED in front of the tv indicate that the set is on, or does it go into standby? Please provide this info so that I can help you with your problem.
Sai.
Aug 15, 2011 | RCA L32HD32D 32 in. LCD HDTV
My philips 64p8342 doesn't turn off
It may be due to many reasons. 1.If your remote is not working or it's battery got over: But then not only the power button, but no buttons will work. 2. If your t.v receiver is faulty: Then also it should not obey any commands, not only power on/off command. So most probably, the power button of your remote is damaged. It may be an internal loose connection. It may happen if your remote has fallen down or anything similar. Get it repaired or have your remote replaced.
Apr 17, 2010 | Philips 64PH9905 64 in. Rear Projection...
The picture on my phillips model number 64p8342 it fades
Looks like your la,p might going out, it starts getting dimmer and dimmer and then it goes out
Jun 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips 64p9161006 Powers on but no picture or sound
Was the screen shrinking or expading prior to failing? Or do you here a chirping sound. If so check www.TvRepairkits.com for a fix.
Mar 21, 2009 | Philips 9P6444C 64" Rear Projection...
Have power but no sound or picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
Jul 02, 2008 | Philips 50P8341 50" Rear Projection...
Philips CRT Rear-Projection TV 64P8342
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Most common death mode)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
