Question about Planar CT1904Z 19" Flat Panel LCD Monitor
Planar monitor Iv owned this for 4 years. About 6 mos ago it would go off for a few minutes at a time. Its been getting worse. Now when I turn it on you can see the screen for a second and still see the shadows. Now it wont turn on. Can you help?
  • 151 Answers
You can check fuse,horizantal output transistor,rectifire ckt on power supply section.Plz do this if you know about this.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 13, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Tip
Planar PX2710MW frequency out-of-range
After a computer reboot, about 8 out of 10 times the monitor would display a blue "frequency out of range" message. It would take several power off/on cycles for the monitor to finally display Microsoft Windows.
I called Planar tech support. They were super-nice. After about 15 minutes in which I shared my screen with them, the tech suggested I go into thePX2710MW's main menu (i.e. "Button 1") and then click "memory recall".
Problem solved! Wow.
on Feb 26, 2016 | Planar PX2710MW Monitor
I have a PE171 Planar monitor. goes black when turned on
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
Feb 24, 2010 | Planar PE171 (Black) 17 in. Flat Panel LCD...
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Auto adjust
i have had the same prob with a pl1700 would like an answer also
Jul 21, 2008 | Planar PL1700 17" Flat Panel LCD Monitor
Pl2010m
This is the same problem I've seen several times. Fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they just can't keep up.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company also. I've seen a lot of complaints for this "international" company.
The fix for most of the problems on these monitors is about $8 on new capacitors (Plus shipping).
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors.
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
-Chip
May 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Planar CT1904Z 19" Flat Panel LCD Monitor Logo
308 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
