Question about JVC AV-48WP30 48" Rear Projection Television
Which IC should I replace if the RED is off?
I had this replaced before and I can see which one was changed. That being said should it be the same IC this time since it's the same color that is off? Does anyone have info on what each IC controls/does?
Thanks,
Tony
  • JVC Master
  • 8,617 Answers
You would need the service manual to dtermine which IC controls the red. One IC controls red and the other controls blue. If the red was replaced before. It probaly went out as some suppliers dont use origional sanyo ICs. Which unfortunately dont last as long as the sanyo parts do.
Posted on Mar 13, 2008
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
When powering up all i get is a red screen with black lines across. Sound is still there and can change channels and ocationaly after several attempts it will give a picture albeit rather green.
Hello
Your TVs video output transistor [Red] has got shorted. Usually a transistors are used in most of the colour telivisions in video output stage.. If it is a transistorised video output stage, replacing red output transistor will solve the problem. In some modern sets there are so many types of Integrated Circuts [ICs] are used. If your TV uses Ic as video output, replace the Ic.
Oct 16, 2010 | Loewe Aconda ACO9303 30" TV
Nokia 3500c memory card not show
inside ur phone there a part of memory card ic or memory ic.. this must be damage.solution you must change the memory ic or replace it..
to pix u must visit here www.gsmsandwich.com.ph
Sep 26, 2010 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Hitachi 50" rear projection worked fine one day then just shut off
Replace this:
--(if led red is off).: IC .STRM6511.
---(if led red is on)....Replace all (3) : STK4274 convergence IC
---Sometimes vertical IC need replace too.
Thank you
Aug 10, 2009 | Hitachi 50UX57B 50" Rear Projection...
Convergence problem
replace the convergence ic. the IC# is STK392-120, replace this two ic at the same time. then put some silicon grease on the back of the IC for better heat transfer. some will work on replacing just 1 IC but I would recommend to replace both per philips advise. hope this help. regards, cebuwano.
Mar 17, 2009 | Philips 43PP9202 43" Rear Projection...
Red colour shadow in the picture
Hi
this means you need to replace the resistor or you need to replace the convergence correction amplifier IC...
Thanks!
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Thought I had a convergence problem - red is still broke
KCOZI,
I dont think you have problem with Red Gun.
One of your Convergence IC is faulty with 2 RK series Resisitor(Low Value) in Convergence
Amp Borad.If you changed IC look for RK series Resistor (may be 3.9ohm/2.7ohm)
Dont forget to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergance- Red X will not move to make crosshairs white. Picture is doubled with red and blue. TV is a 55 in Mitsubishi VS55601.
This problem is related to the Convergence controller IC called STK.It must get malfuntioning replace the STK IC with the same numer IC. But one thing is importent that there must be two IC STK's and you have to change both of them.
Thanks
Oct 11, 2008 | Televison & Video
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence circut
Usually there are 2 convergence IC's, labeled STK392-110. Each IC has 3 channes. Each color needs to be corrected 2 ways, vertically and horizontally, so 6 channels are needed. usually one IC does red, red and haf of green while the other IC does the other half of green, blue and blue. If the red colors are off, change the IC closest to the red jack. If the blue is off, change the IC closest to the blue jack. If the green is out, you have a 50/50 shot at replacing the correct IC. It is recommended to use the STK392-150 when replacing the IC's so it might not be a bad idea to go ahead and replace both with the newer numbers.
Apr 11, 2007 | Hitachi 46UX24B/25K 46" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
