Question about Refrigerators
Kenmore mod. 59672822200 ice
Kenmore mod. 59672822200 ice maker not working. doesnt appear to be power at icemaker molex connector, any ideas, no schematic, thanks Victor
    President:
  • Refrigerators Master
  • 2,651 Answers
You should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Posted on Mar 13, 2008
Kitchenaid icemaker
Hi, you need to provide more details. Does the icemaker power on when its put on and doesnt make ice or it doesnt power on at all? More info is needed pls
May 05, 2013 | Kitchen Appliances - Others
I need a repaire manual for a Kenmore Elite Mod. 10652692100 Ice maker
if your saying you want to stop ice production,simply remove the white front cover on the icemaker and where you will see the large 2" gear look to the upper right side and theres a small round hole with a screw driver fitting,simply take a screw driver and turn that white plastic screw to the left till you hear a click,now the icemaker is off
May 04, 2012 | Kenmore Refrigerators
How to take out old ice actuator on Kenmore fridge
The easiest thing to do is remove the icemaker first. Ujnplug your fridge first, though. Take a 1/4" nut driver and remove the screw at the botton of the icemaker. Then loosen the 2 screws on the topside of the ice maker. You'll be able to see the back screw, but the front one is kinda hidden....you'll have to use your fingers for eyes on that one! Lift up on the icemaker and it should come free from the screws. Disconnect the electrical plug, being sure to release the little latch on the side of the molex plug.
Now you can work on the icemaker....there is a white plastic cover over the end of the icemaker, pull that off and you can start to see the guts of the icemaker. There are 3 phillips head screws holding the motor module on, and the rest of it can be torn down from there. Good luck!
Aug 13, 2010 | Kenmore 57029 Side by Side Refrigerator
I have a kenmore refrigerator M# 253.73872300 S# BA31706989 the ice maker when it calls for water it gets stuck and doesnt stop i had to unplug it now no ice
the fill switch inside the icemaker is sticking or broken gear.replace icemaker est cost $125.hope this helps .please rate my response :)
Dec 09, 2009 | Kenmore Refrigerators
No water to icemaker. Water in door works well.
the water that enters the ice maker is controled by a thing called a solenoid valve (electricaly operated) the" water in door system" is a manual operated valve.. typicaly when the ejector rolls around to put the ice in the tray the solenoid opens lets water in then closes could be solenoid / wireing or controler
good luck
Oct 23, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot ice maker quit
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore side by side ice maker is not geting water. water is on and if I temp change electrical connectors on the silinoid and work the water arm on the door I can get water to the ice tray. What is wrong...
You have a bad water valve . Both solenoids work independently of each other . 1 for the water dispensor and one for the icemaker .The icemaker when 5 degrees and harvests , tells the valve to give it water (electronically) .
Jul 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Mod: 10651262103, icemaker leaking, not making ice
We need to know if the ice maker overflowed or if there is a crack. Sometimes the water gets frozen in the fill tube and diverts the water everywhere other that ice maker. Rare but sometimes something causes the water control valve to stick open on rear of refrigerator. Your ice maker has a thermostat inside it and starts a cycle when the thermostat says the water has frozen. That starts a cycle of about six thing to happen.The defrost element below ice maker warms the bottom just enough to loosen the ice. Micro switches feel and sense the position and as it nears ending the final step the ice maker tells the water control valve to open for a few seconds. An adjustment in that control may stop over flow. But if cracked in a major section it will need to be replaced. Let me know if this helps you. Sea Breeze
Jun 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
238 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
