Question about GPS
Leica 1201 Robotic Station +Allegro CX Data Collector
I am trying to connect my Allegro CX Data Collector to a Leica 1201 Robotic Station. I have connected before but for some reason I am having a hard time getting the settings to work this time?
SOURCE: Phone will not connect to network
hi i was also having the same problem but i installed radio version 1.13 for my mini and the problem is somewhat solved though not completely
Posted on May 21, 2007
jimbo6
  • 89 Answers
SOURCE: no ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Posted on Jan 14, 2008
SOURCE: Data Connections
Did you upgrade your phone to WM6?
I had loads of issues with this until I found the answer on Cingular's forum. Make sure that under Settings > GPRS you have Media Net selected and not the AT&T one.
There's also this link http://www.blackjackusers.com/ which is full of usfull info.
Posted on Oct 12, 2008
Crankstart
  • 696 Answers
SOURCE: Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Posted on Jun 05, 2009
  • 38 Answers
SOURCE: LG KU990 connection to pc doesnt work even with right settings :(
ehmmm firstly try it ina different pc or laptop. or go to the shop where you brought it from and ask them the solution to this.
Posted on Oct 25, 2009
How do I use the Leica TS06 Plus?
leica Geosystems Leica TS06 manual
Type the above into a "google search" and the first item listed is the actually download of your manual.
Mar 30, 2015 | Leica Geosystems Leica TS06 FlexLine Total...
Leica GPS 300 system will not recognize SRAM Card
leica 300 system takes the following pcmcia cards
PCMCIA Cards.
Optional 1MB internal memory.
Type I SRAM cards: 512KB, 2MB. 4MB.
Type II FLASH cards: 20 MB
Types I-III:
Type I: 16 bit Formfactor thickness 3.3 mm.
Type II: 16 bit or 32 bit. Formfactor thickness 5.0 mm.
The original standard was defined for both 5 volt and 3.3 volt cards, with 3.3 V cards having a key on the side to prevent
them from being inserted fully into a 5 V-only slot.
Mar 18, 2013 | Leica GPS
I want to change the dialing number on my allegro GE security system, part no. 60-874-95R. Can you help with this without the vendor's help? Thanks
Follow the instruction on the install manual, page 7. you should start by cleaning the memory of all the previous data - as explained in page 6.
If you don't have the manual get it from here
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ALLEGRO_Install.pdf
Sep 07, 2011 | Allegro Ge Iti Allegro 80-795 / 60-879-95r...
Leica rtk cr344 controller code error 1165
problems on the motherboard of the collector, sorry
Dec 07, 2010 | Leica GPS
GPS Logo
690 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
