Question about Pioneer PL-990 Turntable
Trouble with sound
Bought a NEW PL990.  Having problems setting up to play 33 1/3 LP's.  First it skips ( plays too fast).  Then no sound, very very scratchy, alot of static.  Checked the records, and they're in VG quality.  Any suggestions?
  • Anonymous Apr 15, 2008
    This problem has occurred after fitting a new stylus. I have adjusted the anti skate and the weight adjustment on the arm but I can't obtain a good clear sound.
    Genius:
  • 1,175 Answers
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Posted on May 05, 2008
SOURCE:
When playing LP the sound is bass heavy, but when playing a cd, the sound is perfect.... any suggestions?
The record deck is played through a separate pre-amp to all other functions, so it therefore could be a fault in that pre-amp, but I doubt it. You can fit a wide verity of cartridges in record decks that will each give a different response to the sound. But first check that the cartridge connections are correct. Try swapping them around, it might change what you get. But it could simply be that you have a cartridge that produces a lot of bass. Changing the cartridge to a high quality recommended type - by say some hi-fi buffs website or magazine, might solve the problem.
Apr 14, 2015 | Pioneer PL990 Turntable
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
Got a pl990 turnrtable alot of distortion and terrible sound
Describe the circumstances. Only when played loud or always? What's the proximity of the TT to your speakers. It is NOT immune to airborne sound vibrations.
Dec 27, 2009 | Pioneer Audio Players & Recorders
I have a mid 1970s Sears turntable with am/fm, casette, and 8-track. It plays older vinyl just fine and even one new 45 but my new 33 skips a lot. Could it be the record, do I need a new needle, any...
My suggestion is ask a friend etc with a turntable to try the new LP and see if it bounces on there's. If it plays your old stuff it most likely doesn't need a new stylus. Records are records they don't make them any different to what they used to. Check the new LP, is it warped does it have marks where it jumps?
Sep 17, 2009 | Audio Players & Recorders
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Pioneer PL-990 Turntable Logo
270 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
