Minolta Photocopier EP5000
Machine is daying "Peper remains in the non-sort bin. Please remove"
We can't find any paper stuck in the machine and where is the 'Non-sort bin" anyway?
  • 3 Answers
The non sort bis is the first bin from the top, and by the mean time you can see a hole in the bins for sensing the papers in the bins, the hole from the first bin to the last bin should be un obstructed, as the sensors are on the upper frame and the receptor sensor in the lower frame. so check for any obstruction between theese two sensors through the holes on the output bins
Posted on Jun 16, 2008
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
CS pro EP5000 dead
doubt you find a board for that machine, very very old, get a new machine
Apr 23, 2014 | Konica Minolta DiALTA CF910 Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
Error E502-0000 CANON IR 2200
This problem generates from sorter/finisher ,try detached and disconnect the sorter unit from the machine
E502
Coming off of a sensor connector in an optional device is
detected:
•The door sensor, paper sort sensor, non-sort sensor, bin
outside paper sensor, staple position sensor, etc
Jun 30, 2009 | Canon imageRUNNER 2200
MISFEED ERROR AFTER POWERING DI 2510 PHOTOCOPIER
look for small black levers, and see if they have a piece of paper on it, or if stuck
Jan 22, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
MINOLTA EP5000 CS/PRO
Code COb31 means that the sorter didn't reset after a job. If you try doing a reset by opening the sorter as if there was a paper jam and it doesn't reset, it means that you have a problem with the sensors by the motor that turns the bins to open and clause as the paper passes. Give it a good blow with air. GOOD LUCK.
Nov 05, 2008 | Minolta EP4000/5000 CS/PRO Copier
The paper will not feed through
It could be several items causing that. Lets go simplest to most difficult.Remove the paper tray completely, What you do is pull it like you were going to add paper, but give it a slight lift upward and it will come out. Look in there and you will see the feed tires they are "D"shaped and they should have some texture to the surfice. Take some alcohol and clean them a few times to remove all contamination. But if they are smoothe, they should be replaced. You have to run a lot of copies on them to wear them out though. Also try spinning them a couple of times to be sure the latches that stop them from multifeeding are not just stuck.
You know what, lets do this the right way. After you take the paper tray out. also take your toner cartridge out, then lift the machine and lay it on its back so you can see the peper feeder totally. But make sure you remove the toner before you lay it on its back. You may also want to remove the document feeder prior to laying it on its back. That way you can see the rollers batter, look into where the paper feeds and see if there is anything blocking the paper path. Who knows a small pirce of paper may be stuck in there, or a staple or paper clip.
Then check the paper tray carefully, press the plate down and see if it springs back up.
Once cleaned and inspected, replace the tray and toner and try and run the machine. If if still jams, you want to move the machine out fron the wall and remove the back cover. There are 6 screws holding it on. You will want to look near the bottom of the frame, there is a whits grar, cam type drive . It is white, about 2 inches in diameter and about a half an inch thick. There is a solonoid that engages to release the peper feed, run the machine and see if that assembly is realsed to feed paper. If not, the solonoid or the main board may be bad.
There are metal fingeres in the paper tray also that press right on the corners of the paper to stop multi sheet feeds, they may be slightly bent also. They are on either side of the peper when it is in the up position. You can try seeing if the move freely up and down when the tray is out.
Also when you have the machine on its side, look at the clear mylar strips in the paper feed to see if one of them are tucked under.
I suspect dirty or worn rolls, or something to do with the paper tray. That is mostly where mis feeds occur.
Please let me know and we will look more into it.
Nov 03, 2008 | Xerox CopyCentre C20 Black and White...
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Still the problem
Pls specify the model so that we can give it a shot..
Nov 21, 2007 | Office Equipment & Supplies
83 people viewed this question
k24674
jasbo
jasbo
