Question about Microsoft Trackball Optical USB PS/2 Wheel Mouse MSX0870346
Stiff trackball rotation
Msft optical trackball (5 key) has high resistance to movement of ball. Seems that the 3 metal balls supporting trackball all have flattened tops where they contact the trackball! Anyone know of a source of replacement support balls.
I forgot to mention one other possibility. It's a bit messy, but it sometimes helps...at least in the short term. A friend of mine found that if you eat some fried (basically 'greasy') chicken with your hands and them rub the grease on the ball it works better for awhile. Unfortunately it also tends to gather more dirt into the sunken areas around the metal nubs quicker and the ball movement becomes sticky again rather soon.
Posted on May 07, 2008
Are you sure the metal support nubs have flattened? My experience has been that either they slowly sink into the plastic or that the upper and lower plastic nub supports wear down (which tends to make the ball loose in the carrier assembly). Either way, when the ball gets sticky for me I ensure the metal nubs and the sunken areas around them are clean, then clean the ball with water and find a soft cloth to buff the ball until it is not sticky.
If the metal nubs have indeed flattened you may wish to try removing them and putting them in with the flat side toward the plastic (so you have the round side facing out) - this is assuming they are completely round.
I wish I had a better answer for you. I've have several of the MS TB Optical and only one lasted for a more than a year or so (before the problems mentioned above cropped up). Sadly they are nearly impossible to find and usually very expensive if you can find a new one.
Now if I could only find a way to fix the sudden rapid up/down scrolling mine does occasionally. I've taken it apart and cleaned everything but it still does it :(
Disassemble M570 trackball
You don't need to disassemble it - Under the mouse is a hole, through which you can see the trackball. Insert your pinky (little finger), or the top (eraser) of a pencil, and gently push. The ball will pop right out, and you can clean it, and the three ball-bearings on which it rolls. I do this almost every day. (yes, my hands are clean, but normal oils gum up the ball-bearings.)
Feb 26, 2014 | Logitech Cordless TrackMan Optical...
Mouse ball stops responding, or responds irratically at times. shaking and rotating the mouse 180 seems to provide temporary solution...ball, and sensors are clean (mouse is only 2 mths old...)
Send it back for repair, there is no fixing the chip in a mouse. Sometimes they don't work after one day.
So it depends on how much you paid for it depends on if its work ending back.
This is a great mouse, I only use logitech.
It does have a 5yr warranty.
Feb 04, 2010 | Logitech Cordless TrackMan Optical...
The ball movement isn't smooth, it sticks and jumps past the spot I want to click on.
You might have a dirty ball-holder. Reverse the trackman and hit with it your cupped hand, so that the ball gets out. You'll see a cavity with three round metal prongs and a square dark window. Clean the window with a cotton earbud and the prongs with a toothpick, then push gently the ball in place.
If this does not work, verify the area is free of radio interference and the trackman batteries are fully charged. Also try placing the transmitter at different distances and positions; sometimes the handshake between the units is quirky.
Lastly, verify your PC isn't overloaded and that's the cause of the sluggish mouse movements. Of course, if you "feel" a sticky mouse with your fingers, the cause will be mechanical - the first one. But just in case...
Dec 04, 2009 | Logitech Cordless TrackMan Wheel...
My trackball wont click.
If you could remove the track ball you would see that under it the base is packed in grime and crud. Since it doesn't easily come out, just soak a swab in alcohol, then alternate off rotating the trackball and wiping it down with the swab. Press down as you rotate to try and dislodge dirt and grime. Continue until the ball becomes more responsive.
Nov 09, 2009 | T-Mobile Sidekick
My Microsoft trackball optical 1.0 ps2/usb PN X05-87475 poduct id 52240-576- 3714006-00000 has quit moving the curser on screen. other buttons seem to work ok. Is it fixable.
There is a seller on ebay - Trackballs R Us - that fixes these kinds of problems. Has quite a reputation for fixing Explorer and Optical trackballs and guarantees the work.
Sep 26, 2009 | Microsoft Computers & Internet
My trackball on bb 9000 won't move down
good luck.
if you can get the part -- its a trackball assembly btw not just the ball itself
you press down on the silver ring around the ball and turn, the cover will fall out. use a small probe and lift the assembly out.
many times there's fuzz in there -- check it out before you buy a new assembly
Jul 23, 2009 | RIM BlackBerry Pearl 8100
My trackball is okay with large, sweeping
Background:
I have a total of six Logitech trackballs; four of the newer Trackman Wheel model, and two of the older Trackman Marble+ model (as pictured). All but one of them suffer from the problem described by dave48. The fifth, for some mysterious reason, never has this problem.
Solution:
The solution I came up with is to light a candle and let melted wax drip onto the red thumb ball. A single drip falling on three random places on the ball usually does the trick. (The wax should dry as soon as it contacts the ball.) I then start moving the ball around to work the wax onto the teflon points. The movement will be VERY rough initially, but will gradually smooth out the more you use it. Sometimes the initial three drips aren't enough and the ball starts getting rough again, so I will melt three more drips of wax onto the ball and work them in as well.
Conclusion:
This really seems to do the trick and for some reason the points don't seem to need cleaning as often either. You do have to be careful not to remove the wax when performing a cleaning, however. But if you do happen to remove some wax all you need to do is melt some additional wax onto the ball and work it in like before.
Jun 19, 2009 | Logitech Trackman Marble Trackball
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Kid trackball
A lot of trackball controlls made by Microsoft and Logitech use a optical system. Once the control on the screen doesn't move anymore, you simply remove the ball and clean the optics out of it.
If there is a way that you can remove the ball out of the control, all you have to do is clean the rollers underneath the wheel. After some time they do build up just like a friction mouse does. All it takes is some Qtips and a water alchohol solution.
I would hope for a kid trackball they made that a feature.
Oct 31, 2008 | Microspeed KidTRAC Trackball
MY sk3 track ball is no longer working.
I Can Sell you The Trackball Peice For $35 and if you live in nyc i can even install it for you for another $5, Just Drop a Line to Me 347.845.7151
Nov 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Microsoft Trackball Optical USB PS/2 Wheel Mouse MSX0870346 Logo
548 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
