Question about Canon PowerShot A540 Digital Camera
Shows low battery after putting in new batteries
  • 4 Answers
Your best solution is to use Sanyo Eneloop batteries because of their higher voltage over the discharge curve compared to regular NiMH batteries. See http://www.epinions.com/content_309637189252.
I have gotten a full week of use with hundred of pictures on one charge using a Canon A540 and a set of Eneloops. The only problem is they are hard to find, but you can get them on Amazon.com.
Posted on Jan 29, 2009
    Problem Solver:
  • 5 Answers
Buy a Nikon L11 camera. I gave up trying to carry my Canon A540 around to take impromptu photos, the battery would go dead within a few days. I bought a Nikon L11, put the alkaline batteries that came with the camera in, and it has been going strong for over 3 weeks. The Nikon also has a setting for what kind of battery you are using - alkaline, NiMH recharable ot lithium.
Posted on Mar 23, 2008
  • Canon Master
  • 4,738 Answers
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Mar 13, 2008
  • CameraR
    CameraR Mar 14, 2008
    OK then. Guess that means your camera is not on the recall list. Then how about this?
    Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some battery brands may even have problems just powering startup of the camera.
    Digital cameras for the most part should be used with rechargeable NiMH batteries. Modern NiMH batteries are of much higher energy capacity than Alkaline batteries. Walmart sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
SOURCE:
SOURCE: Low Battery when not
I got this from Nikon Tech support and it worked.
First make sure you are using either brand new or fully charged re-chargeable batteries. If the issue persists, there was a firmware update for the camera to resolve an issue similar to this, and you may need to get the update. To check what version you have, do the following:
-turn the camera off
-turn the top dial to SETUP
-turn the camera on while holding down the MENU button
A splash screen will display and it was say 'E3100 v1.X' in the bottom right side of the screen. If it says v1.1 or v1.2, you will need to upgrade the firmware. For instructions on doing this, please see:
Title: Coolpix 3100 Firmware Update 1.3 - Windows
URL: http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=13030&p_created=1102934617
Title: Coolpix 3100 Firmware Update 1.3 - Macintosh
URL: http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=13031&p_created=1102934414
If it says v1.3, then you already have the update and your camera may need to be repaired.
Posted on Nov 10, 2007
  • 14 Answers
SOURCE: my canon powershot A550 camera behaves as low battery with new b
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
  • 14 Answers
SOURCE: Erratic Low Battery Warning
Voila fixed.
SOURCE: Low battery all the time
remove one battery after using your camera..install again when taking more photos. This solved my draining battery problem.
Posted on Aug 14, 2010
  • 4 Answers
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Posted on Aug 15, 2010
The battery won't hold charge new battery
You put a new battery, now its acting like very low power again?
Most likely the alternator is bad. Maybe not putting out enough to recharge battery. Could have been the original problem.
Can be checked with a meter. Battery at rest should show 12 - 12.9 volts more or less.
With engine running, should be showing 13.5 - 14.7 volts as alternator is pushing electric back into battery.
If you start engine and (after say 10 seconds) voltage stays same or drops, then the charger needs to be replaced. Thats the alternator. Shop around at different auto parts store. (Phone first)
May 25, 2011 | 1989 Buick Riviera
Changed battery on 76 fxe shovel and now theres no lights and wont start by electric or kick , machanic mentioned it was blowing relays and had dead/low battery ( i thought relays auto reset?)
If you still have the old battery see if it can be charged put it back on and try that. If the same thing happens it's not the battery.It's a new problem that happened when you put the new battery on. CK voltage on new battery, check battery fluid, leave battery on charger overnite, then try it. I had a battery that showed full charge then would discharge real fast. Replaced battery and now it works fine. Even a NEW battery can be bad.
Sep 01, 2010 | Harley Davidson FXR Super Glide...
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Showing low battery even when new batteries have been put in
Have checked and its still in warranty, thank you for replying Mags
Mar 30, 2009 | Cameras
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Samsung 301
Rechargeable batteries, do lose their capacity if recharged when partly down- the best way to discribe it is to say they have a memory- but only remember the last bit to be charged. So put the batteries into a torch or similar and leave on until completely flat and empty- then recharge. So do that and buy some new batteries - a couple of sets of batteries are best to have any way. Make sure they are NiMah and the charger accepts NiMah. Then clean out the contact in the bottom the of the battery chamber with the eraser at the end of a pencil. and the contach on the cap. Do that first then come back.
Jul 15, 2007 | Samsung Digimax 301 Digital Camera
Canon PowerShot A540 Digital Camera Logo
543 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
