Question about Fisher Washing Machines
Hi, Wife just called me in and complained that our Fisher Ecellence 7.5 Smart Drive 9 washer stopped dead in the middle of the cycle. I've checked in comming power. Pulled off the top cover put a volt meter across 240v power terminal all ok. Display pannel does not light up all seems dead. Is there an overload or fuse somewhere. Cheers Fred Schaefer
I replaced the controll board and the motor trigger
Cheers
Posted on Mar 14, 2008
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Jan 20, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher and Pakel WL26CW1 code 246
i would say its one of the boards usually the main motorcontroller
Jan 11, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
Our washer was in the middle of the spin cycle and I heard a loud crack sound and everything stopped and I can't even get power. We're thinking maybe it's the belt. One other problem; the water didn't...
Smart Drive washers do not have a belt... If you can't get power, you've most likely burnt out the motor controller board. This is probably due to another component failing...You should call a tech....To remove the water, remove the cone from the centre of the agitator, and undo the large wing nut inside the tube. This will let you remove the agitator and ladle out the water.....Good luck.....Nomess
May 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Dec 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
116 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
