Question about Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh ft4215 problem
Why my ricoh ft4215 xerox machine does not get into ready mode?
  • mrjcgzls Mar 13, 2008
    i need a solution.
Do you get an error code on the display, or does it flash open door/out of toner/out of paper/paper jam or what ?
mikey
Posted on Mar 16, 2008
SOURCE:
Error code on ricoh mp c2500 error sc544 - Ricoh Aficio 2015 Copier
This is a fusing unit error. sometimes is occur by not warm up on time, and sometimes is real problem and need some part in the fusing unit to be replaced. You can try to reset it in service mode and then if machine works its ok. But if it comes again, then a visit by technician is a must. To reset the sc561 you will need to do the following procedure. First of all you need to enter into service mode. To enter into service mode you need to press the following keys on order with no rush. Press the yellow key(clear); then press the blue keypad numbers: ( 1-0-7 ) ; then press and hold for 5 seconds the red key (stop). The touch screen will change into service mode. On the touch screen press [copy sp] ; then on the blue number key pad press the following numbers: ( 5-8-1-0 ) then press the blue key { # }. On the touch screen in the right side will appear a [EXECUTE] press on it and wait to write on the screen [COMPLETED] . After it write [COMPLETED] turn off the machine by the red switch located on the middle-front of the machine left side from the first paper tray. Turn it off and wait for 10 seconds and then turn it on again. Wait for it to get ready. If it get to ready mode, everything is its okey. But if the SC561 code appear again or some similar SC code appear like SC541-542-544 etc. then a visit from a technician must me made to replace some parts in the fusing unit that are wasted.
May 07, 2018 | Ricoh Office Equipment & Supplies
I have ricoh mp 2001L which is printing black
sir my Machines xerox ricoh 2001l but up side lihgt print what reasion sir please solve my problem
Dec 22, 2015 | Ricoh Office Equipment & Supplies
I have a xerox machine for ricoh mp 1600 le. now i have a error of 542. so please tel me what is the problem of xerox machin?
SC542 code on Ricoh's means that the fuser unit is not heating up properly. The fusing unit is the part that "fuses" or fixes the toner onto the paper and is located right where the paper exits your machine. Most of the time the SC542 code means that the thermister(s) in the fusing unit have failed. The thermister measures the temperature in the fusing unit. When these go bad the machine can not "see" the unit heating up so it throws the code. The thermisters will need to be replaced and the code cleared out from the machines memory by gong into the service mode. I would recommend calling your local service provider to effect repairs.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Office Equipment & Supplies
Dead Display on Xerox Phaser 6120
Did you receive any good solutions? I have a Dead Display on a Xerox Phaser 6120. Thanks!
Rick
[email protected]
Sep 11, 2009 | Xerox Phaser 7400/DXF Laser Printer
Problems copying with my Xerox 2515 copier
Paper goes on the bottom first. original goes in top next
Jul 31, 2009 | Ricoh Aficio 450 Copier
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Xerox 3500 blank pages xerox 3450 display flashes
Clear all memory under maintenance will solve this
Feb 05, 2009 | Xerox Phaser 3450DN Laser Printer
Ricoh FT4215 copier with U5 error code
-check if the toner waste bottle is full,if so please empty it.
-are the consumable developer within life?
-if so , then check the vsg/sp settings
Jul 14, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1515F Plain Paper Laser Fax Logo
247 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
