Orange light front of thr i/o panel only no picture
  • Anonymous Jul 29, 2008
    Orange light comes on instead of green light, black screen on monitor. Plus the fan just keeps running.
  • 117 Answers
Hai
it is mother board problem
i had this same problem in dell pc, so call your service person to replace the mother board if it is in warrenty
Posted on Mar 13, 2008
2000 villager radio wiring diagram
Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Green Dimmer n/a Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Light Brown/White Left Rear (-) Light Brown/Yellow Right Rear (+) Light Brown/Green Right Rear (-) Brown/Pink
Jan 31, 2014 | Car Audio & Video
Hi I have a VISCO Flat screen tv MOdel#VSC-32v3 we turn tv on and the orange light is on but no picture does the tv need reset
The orange light typically indicates that it has not detected a video signal. Using your remote, or the front panel buttons, try changing the input source to a known working input. Make sure that your cable from your receiver / dvd player / etc hasn't come loose.
Feb 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Thr printer was printing and just stopped when feeding a new page
“Orange Light blinking and printer not responding” is indicative of no paper or serious ink cartridge issue. Once the no paper is eliminated the scenarios below should be examined. I am saying this from experience.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 06, 2009 | HP DeskJet 845c Printer
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
Color codes for audio wiring on a 1995 ford thunderbird
1995 Ford Thunderbird Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Black/Orange
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: Dark Blue
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
HAVE FUN!
May 24, 2009 | Car Audio & Video
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
1999 ford explorer car stereo install
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
Sep 28, 2007 | Car Audio & Video
Computers & Internet Logo
99 people viewed this question
Alun Cox
David Payne
David Payne
