Question about Frigidaire Affinity ATF7000E Front Load Washer
My affinity washer (front load ATF6000ES) is leaking detergent
My affinity washer (front load ATF6000ES) is constantly leaking detergent that pools on the ground beneath the lower left front corner of the machine. It seem as if all or at least most of the detergent ends up on the floor. Is there way to check if there is a tube that got disconnected? Annother symptom that may or may not be related is there is a loose paddle (on the tumbler inside the drum)
  • 240 Answers
Are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Posted on May 04, 2008
SOURCE:
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
263 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
