Question about Frigidaire Affinity ATF7000E Front Load Washer
(front load ATF6000ES) is constantly leaking detergent
My affinity washer (front load ATF6000ES) is constantly leaking detergent that pools on the ground beneath the lower left front corner of the machine. It seem as if all or at least most of the detergent ends up on the floor. Is there way to check if there is a tube that got disconnected? Annother symptom that may or may not be related is there is a loose paddle (on the tumbler inside the drum)
  • Anonymous Mar 27, 2014
    We notice a reddish oily liquid coming from under the washer in the front left corner on the floor. A leak from somewhere?
    President:
  • 1,314 Answers
The loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Posted on Mar 13, 2008
Reddish oily liquid flowing from under left front corner
Hi Richard, I want to help you with your Frigidaire Affinity washer, model# ATF6000ES. If the reddish oily liquid is coming from the bottom of the appliance, it could be grease coming from the motor area. If the liquid is coming from the dispenser area, it could be either coming directly from your water intake, or possibly a backup in your dispenser area. Hope this has helped.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Nov 06, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
How do i access the water pump on the frigidaire affinity atf6000
There should be to screws at the bottom on each end of the lower front panel. Remove them and the panel will fall down off its upper locating pins and you can then remove the panel. The water pump should be right at the front on the lower right corner. Make sure you unplug the machine first if you are going to be working in there.
Jan 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front loader washer
The E-70 code means your hot and cold water hoses are hooked up backwards. Double check that your hoses are hooked up correctly.
Aug 31, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
438 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
