Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Hi, If the front LED keeps blinking, that is the power supply. Capacitor(s) do go bad on this power supply, a couple of diodes and may be one transistor. You can get the whole power supply for under $100. Let us know... Good luck
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
