Question about Char-Broil 4618376 Grill
Flame uneven how to arrange the bricketts should the metal shroud over burner be covered?
  • 833 Answers
Most Charbroils use an inverted V over the burners. The hot juices and fats drip onto them to make a charcoal type taste. Unless the unit came with bricketts, they're not needed. My unit doesn't have them.
Posted on Mar 16, 2008
Why is cooktop burner flame uneven?
Check for clogged burner orifices.
Mar 22, 2016 | Frigidaire Kitchen Ranges
Tappan signature 2000 adjusting the flame from the burners they are burning yellow
yellow flames in gas burners indicates
1--insufficient gas pressure
2-- the position of the air shroud around the gas jet is wrong and needs to be moved forward or back to adjust the amount of air available for the air /gas mixture
correct mixture is a blue flame
Jan 09, 2016 | Tappan Kitchen Ranges
I don't seem to be able to get the Brickettes Hot
Whether using a gas canister or a tank, To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank. Or remove the canister from
it's holder.
2. Wait 5 minutes and reconnect the hose to the tank. Or reinstall the canister into the holder.
3. Open the tank valve or canister valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
any remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Jul 26, 2011 | Weber Baby Q Grill
I have a monitor 2400 and it is flashing code E01 anyone got an clue what that means
E01 means the flame rod is sensing a flame when there shouldn\'t be one. This is caused by a grounded flame rod or pinched wire. For some reason the flame rod could be touching metal inside the heater. The flame rod could be bent or the burner ring is warped so much that it is touching the flame rod. Another possibility is the wire for the flame rod has somehow gotten pinched. If you remove the front cover and the black grill from the heater, you can see the window into the burner. The plate it is attached to has about 10 screws holding it on. You can remove the plate using caution not to damage the gasket and look into the burner to see what is going on. The flame rod should be centered between the burner ring and the burner. Let me know what you find. If you need to order parts I can help you with that.
Niten\'s Heater Service on Facebook
Jan 17, 2011 | Heating & Cooling
Large burner has uneven and too strong a flame
could be the burner cap. possibly not converted proper. or burner assy bad
Apr 22, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Back burner makes periodic clicking noise and flames increase
This clicking noise would be an indication that the burner is 'burnt out'. Burners have individual ports that release individual flames to create one big flame.
If the burner has a hole in it or the burner's internal baffles are burnt out the burner will make a 'popping' or 'clicking' noise.
Also, heat makes metals expand and when metal expands it makes a clicking noise. The increase in flame could be because the burner has a large hole in it or the holes are increasing in size as they expand, thus throwing a larger flame.
Just a thought.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Mar 20, 2010 | Weber Genesis Silver B Grill
Gas dryer heats for 1 load then glow plug lights but no flame replace solenoid but still have problem
I assume you replaced both coils on the burner. the next likely culprits are the glow bar or the flame sensor on the burner shroud.
eric
Aug 07, 2009 | Dryers
Dvd player seems blocked
if this is a laptop, remove the drive from the laptop and try to put a paper clip in the little hole in the drive to open it manually, if its a desktop then do the same thing, but u dont have to remove the drive from the computer. if all else fails, buy a new one. a dvd burner in a desktop computer is only 40-50 bucks.
Apr 28, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
Char-Broil 4618376 Grill Logo
74 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
