Question about Kitchen Ranges
Amana Gas- Easy touch 500 diplaying code: 5ab
  • lou12412 Oct 09, 2008
    My gas range is in sabbath mode my model is RGSF3330DW i dont have the Manuel on how to move it any ideas?
  • gandgschutz Nov 02, 2008
    I went to change the time on the clock, and the screen reads "5ab".
To cancel Sabbath mode:
1. Press the clock pad for 5 seconds
OR
2. After 72 hours, the Sabbath mode will end.
* SAb will flash for 5 seconds
* The time of day will return to the display
Hope this helps, I took it straightt from my owners manaul :)
Posted on Dec 06, 2008
  • motofox2 Dec 06, 2008
    Hope this solution helps I took it straight from my manual.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Its in SAB (sabbath mode) consult your user manula if you have it will tell you how to remove it. if not post your complete model number ill look up manual
Posted on Mar 13, 2008
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
I have an amana gas range easy touch control 500. the oven will not light every thing else is working fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | Amana Ovens
What does the code 5ab or sab mean my cook top works but not the oven
amana oven reads SAb or 5Ab code? stove works, oven doesnt??? HELP
Aug 21, 2010 | Amana AOCS3040 Electric Single Oven
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
My gas range display changed to "5Ab" and does not work anymore.
You are set to Sabbath mode.
Try holding the clock button in for 5 seconds and that may correct it.
Mar 10, 2009 | Amana RanARG7302 Gas Kitchen Range
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Range does not work-message on stovetop reads 5Ab
same exact thing happened to me! Its not reading *5Ab* it's reading "Sab" as in Sab MODE...PRESS AND HOLD THE CLOCK BUTTON FOR A TOTAL OF 4 LONG SECONDS!! AND WAAAM!! Your stove is fixed and back to normal..with the Time! lol
Oct 10, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
410 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
