Question about Crosley CW5000 Front Load Washer
Was woking fine started to get a burning smell then stopped what can it be and what can i do?
    President:
  • 1,314 Answers
Looking closely at the holes in the tub to see if an object like a nail or similar object might be jamming it then check the belt to see if its loose or burnt
Posted on Mar 13, 2008
3 Suggested Answers
SOURCE: Grinding noise,unit stopped, burning smell?
Just had the repair man come out for the same problem....tranny gone, $600 to repair. Only 3 years old. Disgusted. Good luck.
Posted on Oct 13, 2008
rickyrt441
  • 4399 Answers
SOURCE: kenmore washing machine ultra fabric
Thanks for choosing FixYa and welcome. You need to check the control panel. There is a good chance you can visually see some damage since you smelled the burnt smell. Check your belt(s) as well. Check to make sure the motor is running. Something inside may have burned up. If you have no power, check these below.
Posted on May 12, 2011
BURNING SMELL COMING FROM UNDER THE HOOD
Usually plastic bags that has been whipped up into the engine bay or the underside of the car and has been fused to the exhaust.
Aug 30, 2017 | 1995 Nissan Maxima
Burning smell no overheating stopped running
I would start looking at the wiring try to follow the smell it should at least get you real close.Could be a fusible link?
Mar 26, 2013 | 2002 Dodge Intrepid
Kenmore washing machine ultra fabric care model #92282800. Stop woking suddenly and smell like burned.
May 12, 2011 | Washing Machines
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Drives fine on level terrain start up a slight grade it stops,engage brakes nothing tractor goes backwards will not stop.
When you go up a grade do you smell the belt burning (rubber burning smell) when it starts going backwards on you. It could be that the drive belt is not tight enough.
May 05, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a 4 years old GE top loading washer - model number 2090D... it was fine till last night that it stop at the last ''drain and spin'' cycle... and I smell a burn smell too when I notice the washer...
  It may be possiblr by the way you explained the symptoms, that the tomer may have shorted out .That would be the most likely problem of the burning smell,and the case of no water entering the tub .
May 02, 2009 | Washing Machines
My ge washer starts spining to drain water then stops
Sounds like the belt is loose. The burning smell is the belt heating up. The motor shuts down because it's heating up from spinning on the belt.
Apr 30, 2009 | Washing Machines
Bad sounds, bad smells from 94 ford explorer
Sounds like you may have a vacuum line off or ruptured going to the EGR valve. The burning smell is probably the catalytic converter. When the engine runs rich you will get a sulfur smell that smells sort of like rotten eggs.
Mar 15, 2009 | 1994 Ford Explorer Limited
Intermittent Speedometer Operation
Replace the speed sensor on the transmission. This controls the speedometer.
Oct 07, 2008 | 2000 Dodge Caravan
Crosley CW5000 Front Load Washer Logo
75 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jdthefixer
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
