Question about GE 46GW945 46" Rear Projection Television
3d convergence problem
I was told that this problem occurs often and the culprit is usually a small board located above the convergence board i believe they called it the power supply for the convergence itself they told me to rebuild it it would cost me anywhere from 80 to 110 dollars to fix i got the tv for free and would like to do this as cheap as i can it would be great if i could just find a replacement board and do it that way any help wpould be greatly appeciated thanks
  • GE Master
  • 8,617 Answers
Yes often the convergence anp is the culprit, But 9 out of 10 times its the convergence ICs themselves that go out. At 5.99 each its better to replace them first then if your amp is bad you will have the entire convergence system rebuilt. Where as if you replace the amp and its the convergence you could very well be out of alot of cash that really didnt need to be spent. I would change the ICs first thats alot cheaper.
Posted on Mar 13, 2008
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still...
unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Jun 16, 2009 | RCA Televison & Video
Red color in left bottom of screen and left side has 3d look. letters on guide in this area are concaved also
try to do a convergence adjustment. If that doesnt work the convergence power supply board is the usual culprit, if the convergence option hasnt disapeared from the menu.
Jun 15, 2009 | RCA D61W20 61" Rear Projection Television
Old rca big screen
the convergence is out usually on the crts like this you have to replace 2 convergence ICs usually numbered STK392-110 or -120 or -150 or -180 or somthing similar. Sometimes the resistors in the same circuit are also blown and need to be replaced. I don't know what these are labeled on this tv. It is a pretty simple fix for someone who can use a soldering iron. After replacing the chips a full manual covergence is needed.
Apr 11, 2009 | RCA P52921 52" Rear Projection Television
CONVERGENCE ISSUE *UPDATED* RCA HD52W63D
Convergence Power supply board. In the television above the cuircit boards there are two curcit boards that sort of hang above. the one on the right is the convergence amplifer board(has metal fin like heat sinks).. The one on the left is the convergence power board. Since you have options and no control, bowing picture. this would be my first choice. Now it still may have convergence amplier trouble. To get these boards you will have to get the entire model with suffix ext. it will be like d52w20...yx1 yx2 or something like that. in small leter on the model sticker on back
l
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
What dose a convergence board look like?
This is what the convergence PWB looks like. Its located on the extreme right side of the chassis looking in from the rear of the set.9cc0c04.jpg
Nov 27, 2008 | Hitachi 43FDX20B 43" Rear Projection...
3d picture problem no convergence
we also have the 3D picture and were told that it is on back order ....... any sugestions on what we coul do ourselves????
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
76 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
