FixYa.com
Tags:
Ricoh Aficio 1515MF All-In-One Laser Printer
Out of toner, when it isnt!
posted by copier1user on Mar 13, 2008
The machine said the toner was empty,so i put a new toner bottle
in and it still says out of toner. What do I do?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 13, 2008
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Depending on the kind of copier, all copiers have toner sensor. The sensor flip or botton is out of position. When a toner is inserted in a copier, it is either displacing a flip which open light to a sensor or pressing a sensor botton. In either case a signal in sent to the processor that there is toner or not. Check in the toner chamber, you will it either blocked with dirt. First try power cleaning "Use air preasure".
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Error Code SC 120
HELP. Can you help me with this... Answer This...
Ricoh Aficio Gets strange IP...
Hi I have got an Aficio and it... Answer This...
Error 542
I saw your solution on the site... Answer This...
My Ricoh Laser Printer is not...
I have a Ricoh Aficio 1515 PCL... Answer This...
Ricoh 1515
The cable in the manual feed... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
