Question about HP LaserJet 4L Printer
HP 4L Envelope Feed Problem
Envelopes do not feed through the printer. Normal size paper feed works fine.
  • 21 Answers
Check the internal roller ( central ) easy to remove . clean with alcohol's dry put it back ... (robber couvred)
Posted on Mar 13, 2008
My envelopes will not print -
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Oct 15, 2014 | Lexmark E260dn Laser Printer
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
Printer prints addresses on paper, not envelopes, even though I click all commands correctly.
make sure you feed in the envelopes correctly and adjust the guides to fit the size of envelope you have in the manual feed or paper tray verses the size of envelope you choose in the print settings from the application you are using (MS-Word) e.t.c, also make sure that envelopes have the correct paper type and design for printing i.e( without metalic clips, not too thick to pass through the fuser)
size 10 is usually easy to go through for example.
Dec 03, 2010 | HP Photosmart C5580 All-In-One InkJet...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Dell M5200n Printer is crinkling Envelopes
If you have the option to print in Horizontal or Vertical feed, try the Horizontal option and be sure the feed guide slide is not too tight against the envelope.
Feb 24, 2009 | Dell Office Equipment & Supplies
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Envelope printing
With the address highlighted go to Tools, Envelopes, Custom
Enter the custom envelope size
Pick #4 feed method
click OK
Set the feed tray to hold the envelope along the right side.
Insert the envelope with the flap up - push it all the way in.
Print it
Dec 18, 2008 | HP DeskJet 6122 InkJet Printer
Cannot print odd-sized envelope with 4250 LJ
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
HP LaserJet 4L Printer Logo
196 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
