Question about HP Photosmart 8250 InkJet Printer
Ink system failure
Is buy another printer the only fix?
  • 20 Answers
No buying another printer is not the only fix however Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Posted on Jan 02, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • HP Expert
  • 105 Answers
You can find a reset for the HP ink system failure at: http://www.inkbank.com.au/webcontent21.htm
It is for HP C7180 model, but might work with yours too...
cheers L.C.
Posted on Apr 02, 2008
4 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Ink system failure
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Posted on Oct 15, 2008
I had exactly the same problem with my HP 8230 and tried all the posted sugestions with negative results till I stumbled on this site site offering an update for a different problem but added " also clears many ink system failure messages " I downloaded and installed the update and the printer burst into life and now works perfectly, which proves mine was a software problem not a hardware one. give it a try you might get lucky.
http://www.birseyindir.net/driver/HP_Photosmart_8230__Print___12760.html
Alan
Posted on Jan 05, 2009
Open the printer as if to replace an ink cartridge. On the print head there is a black plastic arm about 2 inches long. Re-connect this with the white cog wheel so that the protruding part is in the center of the black arm. Close lid, power on and job done.
Posted on Nov 16, 2009
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
Started with out of colour ink - changed coluor ink cartridge. then came up with out of black ink - so changed the black ink cartridge now sais scanner failure when run through procedure to align...
"Scanner failure" basically means buy a new machine. Once the scanner fails on an all-in-one it will refuse to do anything. Replacing or fixing the scanner will cost much more than buying a new machine.
Sep 28, 2010 | HP PSC 750 All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer is showing ink system failure. what does this mean? how can it be fixed?do we just need to replace all of the ink cartridges? help!
Ink system failure indicated that ink delivery mechanism of the printer is experiencing problem. We need to do below resets for this printer to fix this issue.
Solution 1:
  • Press the On button to turn of the printer.
  • Unplug the power cord from the back of the printer and from wall outlet or surge protector.
  • Removed all the ink cartridges
  • Wait for 2 minutes
  • Connect the power cord and turn the printer On.
  • Install the ink cartridges
(Please go to solution 2 if the problem is not resolved)
Solution 2:
  • Remove all the ink cartridges.
  • While the printer is ON, unplug the power cord from the back of the printer.
  • Press and hold OK and Cancel button, while holding these buttons connect the power cord.
  • Release the button after 20 seconds.
  • Turn on the printer if it goes off and install the cartridges.
Regards
Riztech
Mar 04, 2010 | HP Photosmart 3210 Printer
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Hp photosmart 8200 Ink system failure free standing not hooked to compurter printing directly from printer installed new ink cartridge and ink system failure still...
We took it to Best Buy and had the Geek Squad look at it. After checking it out they suggested it would not be money well spent to have it fixed becase of it's age.
Apr 29, 2008 | Office Equipment & Supplies
HP Photosmart 8250 InkJet Printer Logo
811 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
