GE Microwave Where is the thermostat (flame sensor) located on the GE Profile Microwave oven model #JVM1660BB008. The p/n is WB27X10195. Thank you!
  • 86 Answers
Thermostate sensar fit on cooling coil.near selector switch
in split a/c thermostate fit in indoor unit.c the thermostate open indoor unit.
Posted on Mar 15, 2008
Flame Sensor not available
We could look it up if we knew your full model number, but some of their budget models (like some made for Wal-Mart) are made with only turntable parts available.
Within the warranty period, the oven is to be returned to the dealer.
But a fire would not normally be covered under warranty unless the oven came on by itself when idle.
Otherwise, the thermostat / TCO has temperature markings on it, and a generic equivalent or very close type can be matched at a local appliance parts store.
May 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    WHat part number for this GW Microwave oven thermostat?
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    It will tell you where each one is located and what it's called, and should have the part numbers.
    Three of them should read normally closed and one should read open.
    You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
    If you still need help, let us know.
    Jul 04, 2009 | GE Microwave Ovens
    GE Microwave dead
    Chances are the flames opened the oven cavity TCO, which acts as a flame sensor.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    You can also find helpful exploded view diagrams and order parts by entering your full model number here.
    Accessing some components (cavity TCO) for testing and possible replacement will require you to remove the oven from the wall.
    If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
    You can download GE owner's manuals and installation instructions here.
    Jan 31, 2009 | GE JVM2070 Microwave Oven
    Ge model Jvm1563wh05 microwave oven
    I assume that model is JVM1653WH05?
    The fire probably opened the internal flame senor, also known as the oven cavity thermal cutout (TCO) located on top of the cavity.
    The TCO part number is WB27X10195 and it's available here.
    You can find helpful exploded view diagrams here.
    Accessing the cavity TCO will require you to remove the oven from the wall.
    Jan 27, 2009 | Microwave Ovens
    GE PRofile Microwave runs but no heat
    This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
    PLEASE rate my response to your question
    Thank
    You!
    Jan 10, 2009 | GE JVM1870 Microwave Oven
    How to replace thermal fuse/flame sensor
    GE JES 1358 WK 01 microwave:
    I recently had the same problem with a "flame sensor, " aka "thermal switch." My microwave is a "throwaway" model, very few repair parts available. I didn't want to replace it, so I did a little bit of research into thermal switches. I actually found one that would replace it for about $5 (plus $5 shipping).
    Mine uses a "bimetal" thermal switch. There are three kinds of bimetal thermal switches: automatic reset, manual reset, and "one time use." The really interesting thing is this: the "one time use" resets (!!!) if the ambient temperature is below 0 degrees C, or 32 F (freezing); or, in some cases, -31 C, or about -22 F.
    I put my "dead" flame sensor in the -10 F part of the freezer for about 20 minutes...
    Checked it with my multimeter, and the once-dead sensor now read continuity (zero ohms)!!!
    Reinstalled it in the microwave, and now it works fine.
    So if you have a dead sensor- try freezing it...
    Sep 21, 2008 | Microwave Ovens
    Need to replace Thermostat or Thermal fuse
    GE calls them TCOs or thermal cutouts.
    There are three in this model and they can all be ordered here.
    The reference numbers relate to the drawing here.
    REF# PART# DESC
    111 WB27X1127 TCO -BOTTOM
    59 WB27X10195 TCO -CAVITY
    104 WB27X10194 TCO - HOOD
    101 WB27X10388 FUSE
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. It usually shows relative component layout.
    Aug 19, 2008 | Microwave Ovens
    Heating & Cooling Logo
    154 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Marvin
    Marvin
