I went to turn my pc on and the hardrive hase stopt spinning wot do i do
    Sergeant:
  • 349 Answers
If you see no lights on at all, no fans going or any sign of life, it may be the power supply that has died.
if you see lights on but the pc does not boot up (turn on) it could be one of many problems , we need more information
as it could be:
  • bad cpu
  • bad motherboard
  • bad memory chip
  • bad hard drive
  • fluctuation power from the supply
as you can see more info would be good, as that is the only guide we have .
good luck
Terry
Posted on Mar 13, 2008
SOURCE:
Samsung n145 plus operating system not found
Hi There,
"operating system not found" generally means that your hardrive is dead. Listen to your laptop when you turn it on - if you can hear the harddrive spin up, you can probably access the recovery menu through the F10 function.
If not, you'll need a new hard drive and to reinstall your OS.
Thanks
Jun 07, 2012 | Samsung Computers & Internet
Will not boot up
Ive done a few dell mini notebooks and this problem was always corrupt hardrive or the hardrive died. Solution take hardrive out plug it as external into another pc see if it spins up and you see it show up on pc. If it does then itll be just corrupted and will need windows reinstalling. If it doesn't youll need another hardrive itll be dead. There not expensive depending on what size you wanting. Hope this helped.
Feb 19, 2012 | Dell (INSPIRION MINI 10) Netbook
I have have a new hardrive but the my old monitor has a problem
the usb port that your new hard drive needs is USB 2.0 whereas monitor has 1.0 SO IT WILL NOT WORK.
Feb 22, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Wot spin the disc
The issue that you are having is that the motor and/or cd-rom/dvd-rom drive for your ps2 has gone bad which has actually occurred with a lot of slimline playstation 2's.
Sep 27, 2009 | Sony PlayStation 2 Slimline Console
CD rom drive not showing up in
Common problem. CD driver did not install correctly.
Go to Device Manager. Unistall the CD drive. Reboot.
The Operating System will then rescan, locate the drive, and reinstall the driver.
Good luck.
Jan 09, 2009 | Computers & Internet
Put camera on screen come on lens came out thwn power went off now power light wont stay on long enough lens wont go back in
maybe this works: turn your camera on in play mode (if you have play button press it to turn on camera) and if your camera hase a shoot-play switch select play mode and then turn your camera on.) repeat this until lens goes back. I hope this works...
Nov 01, 2008 | Samsung Cameras
Good day,after reformated my pc,its sound went off,the make is hasee f420s.pls help me,how can i recover its sound back,cos i dont have the cd of the pc
Best bet is to google your comp to find the specs of it. once you do that find the name or type of ur audio onboard device and download the driver.
Oct 21, 2008 | Computers & Internet
Sony NW-A1000 will not play,
If you get the spinning disc error on your sony nw a1000 it means the hardrive is knackerd.
The hardrive in the sony NW A1000 is a segate ST1.2 6gb and these can be bought off ebay for around £8. If you can't find a 6gb one you can fit an 8gb hardrive BUT your NW A1000 will only use 6gb of it.
If you search on the internet you can find instructions on how to remove the back cover of your NW A1000 which is very easy to do! You then unplug the hardrive (be very careful!) and replace it with the new seagate hardrive. Turn the NW A1000 on and go to the home menu, select "settings", then select "intialize disc" and it will format your new hardrive so that it can work with NW A1000.
Jul 02, 2008 | Sony NW-A1000 MP3 Player
Power is on but I have a blank screen
Sounds like the hard drive crashed. Make sure the hard drive is seated back in properly, then hit the power button and listen closely. You should be able to hear it spin when the hard drive engages. If it does engage, you should hear it spin smoothly, if there are any clicking or dull thumking sounds, then it's shot and needs replacing.
Jun 19, 2008 | Gateway MX3414 Notebook
Open Questions:
MALWAREBYTES I{855=536*5666} Malwarebytes tEchnIcal SUpPoRt nUMber usA O** Malwarebytes Antivirus TechNicAL Support Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 16, 2019 | Carrier Computers & Internet
MALWAREBYTES 1[+`855/536~5666] Malwarebytes Antivirus CUsToMeR CArE nUMber O** Malwarebytes Antivirus CuSTomEr CaRe Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
SBCglobal MAil TecH SuPPoRt {1^855^536^5666}#[email protected] PHoNe NuMbER CUSTOMER This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
