Broken Computer Ok i have an Emachine W1700 and i hook it up to everything and i push the power button and nothing happens. The H.D.D. LED;POWER LED;and the POWER SW all have been moved around and i dont know where to put them.
Jkdhksjdfh
sdlfds
fdslkf;gjufe
kg;drpgk
efpkgek
hk
p
Posted on Mar 13, 2008
SOURCE:
Dell W1700,all is black ,no sound green power LED
please checks all connection ast the back of your monitor... at the very bottom. you might not put it properly
Aug 09, 2009 | Dell Computers & Internet
Emachine T3624 will not power up
Emachines are notorious for having faulty power supplies. If your lucky you just need to replace the power supply. I've seen a lot of them where the power supply also fried the motherboard.
Please don't forget to rate this solution.
Jun 15, 2009 | E-Machines T2984 PC Desktop
Emachine Monitor comes on a few minutes and cuts back off
I have the same problem and I think its the circuit board on the power on button and blue led. I unplug the board when the monitor is on and then the monitor stays on and works OK.
It don't make any sence it is only 3 parts switch led connector
anybody else run into the problem
Mar 29, 2009 | E-Machines eMachines Monitor E15T4
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
Compaq presario 2500 notebook won't boot
This sounds like a weird solution, but it worked for me. I recently bought a used Presario 2500, it worked when the guy showed it to me, when I got home it didn't work two days later. I tried several tips from the web, finally I started pushing several buttons randomly. I pushed the Email (Envelope) button, and the computer powered on suddenly. Now, the Envelope button is the only button that will power the computer on. When the computer is on, that button will also bring up Outlook, but when the computer is off, that button turns it on. Let me know if this fixes it for you.
Dec 11, 2008 | HP Compaq Presario 2500LA Notebook
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Motherboard Change
Need to look in the manual to find where they go. Don't just try at random or something will fry.
Jan 21, 2008 | Intel Motherboard
Open Questions:
TOSHIBA customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This TOSHIBA USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 TOSHIBA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the TOSHIBA USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, TOSHIBA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA USA Calling TOSHIBA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA USA's phone numbers against each other. Contacting TOSHIBA USA in General While I8OO8O31O69 is TOSHIBA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA USA.
Oct 18, 2019 | Toshiba Computers & Internet
\Q;- PANASONIC customer support phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This PANASONIC USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 PANASONIC USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the PANASONIC USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, PANASONIC USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANASONIC USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANASONIC USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANASONIC USA Calling PANASONIC USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANASONIC USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANASONIC USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANASONIC USA's phone numbers against each other. Contacting PANASONIC USA in General While [+I8OO-8O3-1O69] is PANASONIC USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANASONIC USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANASONIC USA.
Oct 18, 2019 | Panasonic Computers & Internet
KODAK customer support phone {\#;-{+1'8OO;8O3^1O69} NuMbEr USA .ANITA This KODAK USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 KODAK USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KODAK USA customer support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, KODAK USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KODAK USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK USA Calling KODAK USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK USA customer support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK USA's customer support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK USA's phone numbers against each other. Contacting KODAK USA in General While I8OO8O31O69 is KODAK USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK USA.
Oct 18, 2019 | Kodak Computers & Internet
\Q;- HP customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This HP USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 HP USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the HP USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While [+I8OO-8O3-1O69] is HP USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
Computers & Internet Logo
139 people viewed this question
Ekse
Alun Cox
