Question about V-Stream Xpert 1280x1024 LCD TV Box w/Remote (112233)
Power - AC Adapter
Lost the original one and it doesn't say what power it takes - is it 12V DC ? (or 18 V DC or 5 V DC?) if anybody has one.. please replay
12 volts DC-1 amp
center pin is +
Posted on Dec 30, 2008
  • 818 Answers
5V DC seems that this works.
Sergio
Posted on Mar 13, 2008
Replacing power supply in a Cuisinart CWC 1600 cooler
Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. his power supply replacement takes about 20 minutes. You need: Philips screw driver, wire cutter and stripper, two 16 gauge wire nuts. That's it.
Dec 01, 2017 | Furniture
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Power cord
If the voltage is the same, and the current of your replacement adapter is equal to / greater than the original, it should work perfectly fine.
BUT..
The only thing to pay attention to is if it is AC or DC. AC requires nothing more for you to do. DC however, will require that you have the proper polarity: PLUS (+) and MINUS (-) on the mating plug contact points. If you guess at this, you have a 50/50 chance of turning it into "toast". If the socket is unmarked, contact the manufacturer to obtain polarity information BEFORE connecting!
May 16, 2013 | SimpleTech Computers & Internet
Where can i buy a ac adapter - model js-12060-3k for a packard bell tv?
Here some sites I found using Yahoo. Please make SURE that the output voltage & amperage from the new adapter is correct for your model. It should be on the back of the TV by the model & serial # or where the adapter plugs in. If you have the original to consult, that's your best bet. I hope this helps & good luck!
http://www.powerpayless.com/12v-6a-jewel-js-12060-3k-ac-dc-power-adapter-equiv.html
http://www.pchub.com/uph/laptop/345-42623-12247/Jewel-JS-12060-3K-AC-Power-Adapter-5V-12V.html
http://www.lcdpayless.com/productpage.php?productId=1963
Jul 06, 2012 | Computers & Internet
Which 12V DC power adapter should I used?
first of all what is the power rating of your speaker
Mar 19, 2009 | Yamaha YST-M7 Computer Speakers
Microsoft Force Feedback 2 joystick - Lost Power Supply.
Hope this helps.
Part No. 96749 (Maybe Ebay?)
Input: 230V~ 50Hz
0.15A
Output: 12V 1.3A
Apr 28, 2008 | Microsoft SideWinder Force Feedback 2...
V-Stream Xpert 1280x1024 LCD TV Box w/Remote (112233) Logo
487 people viewed this question
Top V-Stream Televison & Video Experts
Marvin
Marvin
Are you a V-Stream Televison and Video Expert? Answer questions, earn points and help others
