Question about Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S269 AC Power Adapter
I just had a flame shoot out of the molded end of my AC Power Adapter. The box had been giving me intermittent power for the last couple of days, and when I picked it up tonight, a flame shot out and melted a hole in the wire. Is this normal?
No it isnt normal and isnt safe either. DONT USE IT! Buy a new one on ebay and throw the other one in the trash.
Posted on Apr 10, 2008
SOURCE:
M45-s269 battery
any how i hope the above helped (refer to comment) and happy computing
Feb 03, 2012 | Toshiba Satellite M45-S269 (PSM42U016006)...
Power comes on then immediately turns back off
Check if the computer turns on only with the adapter (ie; Remove the battery and then plug the adapter alone and then check if the computer is turning on.) If it does not then then the adapter is gone bad and the battery is empty, so change the adapter.
If it does then change the battery... The battery is gone bad...
Nov 22, 2010 | Toshiba Satellite M45-S269 Notebook
My toshiba M45 takes several times to turn on,
what is your operating system? if you're familiar of what you're using, then it might be a hardware issue, please be specific,
if you're using windows, try running your OS to safe mode by turning it on and pressing F8 after bios load, it might be your Operating System is corrupted...
Mar 18, 2010 | Toshiba Satellite M45-S269 Notebook
Laptop will not power up, ac adapter issue, battery, or someting else?
You can try taking your battery off the laptop and just have the power supply hooked up. If it will start up like that, your battery or the charging portion of your motherboard is probably bad and you should have a technician look at it. If it doesn't start, your power supply is more than likely bad and you can order a new one from eBay. Also check to see if there are any lights on the computer or power supply. If the laptop has lights on it is almost definitely a laptop issue, if nothing is on (including the light, if there is one, on the adapter) then it's probably a adapter problem and your battery is dead. You could try getting a new one on eBay or a universal adapter in a store. That way if the adapter turns out to be ok you can return the universal adapter.
Jan 24, 2010 | Toshiba Satellite M45-S269 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Satellite M45-S269 Power connectivity
Either defective AC adapter or DC connector(common problem) needs to be replaced
Mar 24, 2009 | Toshiba Satellite M45-S265 Notebook
Accidentally rotated the monitor screen by 90 degrees.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1132269&rpn=PSM42U&modelFilter=M45-S269&selCategory=3&selFamily=1073768663&selModel=1132269|PSM42U
according to the downloadable user guide at toshiba support page , it appears , FUNCTION / SPACEBAR keys switches the landscape / Portrait modes . have you tryed that . good luck .
Dec 25, 2008 | Toshiba Satellite M45-S269 Notebook
A litlle problem?
You don't need to worry about it unless u start having issues with the battery backup or charging. Revert back if you having any issues till date.
Feb 11, 2007 | Toshiba Satellite M45-S2692 Notebook
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
129 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
