Question about SharpVision XV-Z9000U Multimedia Projector
Lamp life over 2000. can't turn on again after replaced
Unable to turn on.  Think kids have run lamp life beyond 2000 hours.  Is there a way to reset power on.  I have replaced bulb and am still unable to turn on .
Sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Posted on Apr 21, 2009
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
www.projectorreviews.com/articles-guides/lamp-life-and-brightness-2/
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
https://community.spiceworks.com/.../2235-resetting-lamp-hours-on-a-sh...
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
https://www.youtube.com/watch?v=sPGZSJXpxqI
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
I want to find out the life expectancy of the bulb (lamp) that comes with the Optoma projector model VDDVGG
We tracked it when we first bought ours. The lamps go anywhere from 800 to 1200 hours. First, I don't think the manufacturing process is very consistent so they very a lot. Also, it seems the more you turn them on/off the shorter the life. If you use for longer periods, then they last more hours.
You might be able to get 2000 hours out of one if you just leave it on without turning it off but that is a waste too.
-Mark
May 18, 2011 | Audio Players & Recorders
New lamp fitted to a 6121 uint but it says replace lamp as life has reached more than 2000 hours
Follow the procedure in the manual, as this counter needs resetting too. There may be a reset button near the lamp or cover.
Sep 02, 2010 | HP VP6121 Multimedia Projector
Newer lamp not workering
I don't think that resetting the lamp is the problem if you have had it in there for a few months already. This lamp is rated for 2000 hours. That is abaout 1 year if you use it about 5 or 6 hours a day. If you don't use it that much you should get close to 2 years. There are a variety of factors that will reduce the life of your lamp. Do you let the fan continue to run after the projector is turned off? If not, you will see about half of the regular life. Are the filters clean? You can use a vacuum or rinse out foam filters to clean out the dirt and dust. The lamp needs good air circulation to cool evenly. Are the vents blocked or close to another componant? I'm pretty sure that you just need another lamp. If the lamp was purchased more then 4 months ago, you are probably out of warranty. You can save yourself some money if you buy the bare bulb and replace it in the old cartridge. It looks like the complete lamp module from Sharp runs around 295.00 but the usually have a bare bulb available. We supply a variety of brands fior each projector. You can contact me at 866-470-9877 or go to allprojectorlamps.com. Good luck!
Jun 26, 2010 | Sharp XR-11XC DLP Projector
Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Office Equipment & Supplies
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Re44sz21rd
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Sep 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
BENQ PB2140 PROJECTOR - RESET LAMP AFTER REPLACEMENT
Hi Terence
Yes you have to reset the lamp timer.
How to do this :
1.) Hold in the up arrow key on the Projector for 5 seconds , a on-screen display will appear in the top left hand corner.
2.) It will read : Press left or right and then Menu or Auto.
Just follow the steps and the lamp timer will be reset.
Thanks for using Fixya !
May 19, 2008 | BenQ PB6100 Multimedia Projector
SharpVision XV-Z9000U Multimedia Projector Logo
548 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
