Question about Vivitek V37835 46 in. LCD Television
Vivitek 51 DLP HD HDMI
The tv when turned only comes on for a minute then it flashes a yellow (on top right side of front) and then a green (under yellow flashing light) and it won't bring up the picture....HELP!!!!
  • st1957 Mar 16, 2008
    I have a 56" DLP HD TV and after awhile watching the tv the screen goes blank and the lights blink on the panel board with the light flashing on the lamp status
You should have checked the troubleshooting section of your manual!! Okay, enough scolding. You need a new lamp. I do enjoy my Vivitek, but this is a definite downside of a DLP, especially if you watch a lot of TV. I am on my third lamp already, and they are NOT inexpensive. If you have your TV less than a year, your lamp may still be covered under warranty and may be replaced by Vivitek for free. If you have to buy your lamp, it can easily cost you over $200. This is the new lamp in a whole new assembly, which makes installing it EXTREMELY EASY and will just take a few moments. If you are a little more adventurous and want to save some money, you can buy the lamp alone. You then remove the lamp assembly from the television, open it up (there's several screws to remove), disconnect the old lamp, and reverse the process by making the proper connections with the new lamp and putting the new assembly back together and back into the television. It sounds more complicated than it is.. Biggest rule.-- don't touuch the surface of the lamp with your bare hands. You don't want your oils on the lamp. . And once you put everything back together and restart the TV, reset the timer for the lamp (the manual explains how). The lamp timer is very important for warning you of when to replace the lamp under ordinary conditions, when it does make it through its entire expected life. I don't know if it's appropriate to actually recommend specific vendors for the lamp, but I can if that's okay. email me midlomiss at yahoo dot com
Posted on Jul 21, 2008
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
Looking for the enter code for vivitek tv model # rp51hd41-a a 51" micro display projection tv
your cable or satellite will do just fine. i have a vivitek rp51 and i was told that if i lost my remote i was SOT well i found out that the parent company of vivitek is DELTA and wouldn't you know it i programmed my direct tv remote using the brand delta wich was on the list and it worked... by the way vivitek is not on any list for remote control codes....
Jan 14, 2010 | Vivitek V37655 56" DLP TV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Need help w/ HDTV
Have you ever replaced the lamp in the TV? Usually the owners manual will tell you what the flashing indicators mean on the front. The lamp would be my first suspect.
Nov 12, 2009 | Televison & Video
Tv will not go on
This exact thing happened to us and it was the bulb. You need a new one. Luckly ours was under warrenty and it was replaced for free. Once replaced the problem was gone.
Jun 08, 2008 | Vivitek V37835 46 in. LCD Television
Tv codes
THE TROUBLE CODE IS 32. YOU NEED A BULB.GET READY TO PAY BIG MONEY, I'M SORRY I BOUGHT A VIVITEK.
Jan 14, 2008 | RCA P52939 52" Rear Projection Television
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Vivitek V37835 46 in. LCD Television Logo
421 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
