Question about Sewing Machines
Singer 241-11 I am teaching myself how to use this machine. When I attempt to sew a cushion it works well for a while but then the needle breaks. The needle is a number 14. When I switch to a number 16, which for some reason the thread in the bobbin is not being pulled up therefore I can not stich a seam. Help.
  • la_buchua Sep 08, 2008
    I need to arm it ?
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
My 6110 Singer sewing machine was working great but it stopped and started breaking the needles how can I fix it?
Sometimes, you do not have the needle inserted all of the way up. Make sure that you have the right gauge needle for your project. The higher the number the thicker the needle.
Mar 28, 2018 | Singer Sewing Machines
How to the timing on a sewing machine
all sewing machines are the same a very simple. to adjust timing so the bobbin catches the thread, just slightly loosen screw on the main needle shaft(the one that has the needle and goes up and down), move the flywheel so that bobbin point is behind needle at lowest point, tighten screw. test it out. you cannot break the sewing machine, tho you can break a few needles as you master the timing technique. dont be afraid to try. it really is easy. one summer many, many years ago, while i was in college i worked for singer in a singer store. things havent changed since then. (almost 45 years ago). good luck
Jul 28, 2014 | Singer Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
Thread keeps breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
I have Singer 5040c machine i was cleaning this machine it was working fine before, but machine is breaking needle all the time ,i can't sew anything, i just remove belt from bottom part cleaned it...
Your machine needs a professional to fix your timing and tune it up. You may have messed up the timing when you took off the belt. It is worth getting it fixed.
Sep 19, 2010 | Singer 5050 Mechanical Sewing Machine
I have a Singer Sewing Machine Model 4562 T I
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
What happened singer?
I can give you a REALLY long answer or a short one. If you really want to solve your head aches I would look to a diff. machine. You will never be happy with this one. I get this all the time. Hubby is a good guy for getting you a machine, he tried. If he did not get it at a sewing machine dealer than that is what needs to happen. A dealer will give you support, training, warranty and the rest. You may even get a trade in on that one, just ask. You are correct the old Singes are a real machine. The new ones are just a name.
Aug 03, 2009 | Singer 3116 Simple
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
587 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
