Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Tv problem power-on led blinks on 7 off when tv is off
  • jimban Mar 13, 2008
    This is a Mitsubishi WS-55315 there is no reset button on the front panel to reset with a paper clip.
    Scholar:
  • 104 Answers
On the front panel there is a system reset switch. Use a paper clip to press the reset button. For more troubleshooting info you can get the manual HERE.
Posted on Mar 13, 2008
  • Barry Gardner
    Barry Gardner Mar 16, 2008
    This solution is appropriate for the model 55513 tv for which it was
    originally listed. The link to the manual is for the listed model, and
    the solution for the problem is correct for the model listed.
How do I fix my Panasonic Plasma TV?
Call in a repair specialist. You have done everything you can do.
Nov 18, 2015 | Panasonic Viera TC-P50S2 50" Plasma TV
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Feb 20, 2009 | Televison & Video
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
