Question about Zenith R57W46 57" Rear Projection Television
Old tv's I have an old projection tv and the picture keeps going black! do I need a new picture tube? and how do I get one and how much does it cost?
  • Zenith Master
  • 8,617 Answers
I dont think you need a picture tube. If the audio still works when the picture goes out I would suggest checking the solder on the vertical output IC that could make the picture tubes blank out. Look for hairline cracks and resolder just to make sure. Let me know how you make out or if you need more info.
Posted on Mar 13, 2008
SOURCE:
I need a picture tube for my 50in.Sony t.v . I live in central MI. Need to know where & how , to buy & fix the pic.tube Thank You...
projection screens dont use tubes,a 50 inch tv tube will cost 1000 a new flat screen tv is alot cheaper,buy a flat screen hd ready tv
Apr 16, 2015 | Televison & Video
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I need a picture tube for my mitsubishi vs-5051 40in projection tv, how much do they generally cost? whats a good website or store in my area of manor texas?
Honestly, sorry to give you the bad news and I'm one for trying to repair then throw out but, buy a new 42" flat panel it will be a lot cheaper. Mitsubishi quite making these size CRT's over 5 years ago and a replacement tube would cost more than buying a new replacement 42" TV.
My thoughts is that this 5051 is over 13 years old.
Blessings,
A/V Media Tech Guy
Nov 18, 2009 | Televison & Video
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
How much would it cost me to replace the picture tube for rca big tv screen that i got it for free ? where do i buy it at ?
A CRT (picture tube) for an RCA projection TV will cost $300-400 If the TV is more than 4-5 years old, you'll likely have to replace all 3 CRTs to obtain a watchable picture. Its probably not a good idea to spend that kind of money on a "free" TV.
michtech
Feb 18, 2009 | Sony KP-57HW40 57" Rear Projection...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
104 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
