Bionaire BSH3818 Heater Instructions
Just bought this and there are no instructions inside - How do you regulate temperature?  Does it shut off when it reaches a certain temperature?
Thank You!
    Problem Solver:
  • 5 Answers
I think on that particular model you just set the timer and it will run automatically until the timer runs out. Sometimes if you go to the manufacturer's website you can download the user manual, or at least get a phone number to call and request a manual be sebt to you. hope this helps!
Posted on Mar 13, 2008
SOURCE:
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
Why does my whirlpool senseon dryer start when i disconnect the thermistor wire but then shuts off after a minute?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Apr 08, 2015 | Whirlpool Dryers
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
I need help
amazon.com has the manual for you to download or purchase. and also does the bionaire website. which is www.bionaireproducts.com
Apr 22, 2009 | Bionaire W7 Humidifier
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Wiring thermostat
a standard propane regulator should work. check on the required pressure for the unit and get a compatible regulator. try grainger supply. thermostat connections are usually 24 volt two wire, opens on temperature rise. connections on the burner relay are indicated TH-TH.
Nov 11, 2007 | Mr. Heater MHU45LP
How to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
Jun 19, 2007 | Bionaire BW2300 Window Mount Fan
Heating & Cooling Logo
534 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
