Question about JVC AV-24F702 24" TV
Sd tv inbalance screen.
My tv's screen is not balance. the left side is lower than the other side. i saw a technician before fixed a sd tv with thesame problem as mine using just its remote control. i saw him pressing some code or something to the remote. do you guys know what that code is? thanx.
  • chao_13 Mar 15, 2008
    yup i got into it already but the there's nothing there that can solve my problem. my tv's left side of the screen is lower than its right side. there's an option there to adjust the screen but the prolem is both side are lifted at the same time. is there an option where i can just adjust the left, leaving the right side as it is. sending my tv to the technician is really my last option, the last time i let them fix my tv was a disaster. i got traumataized.hehehe... thanx to BFix, hope u could help me out here again. : )
  • chao_13 Mar 17, 2008
    thanx. i'll try give it a shot.
    Scholar:
  • 104 Answers
There is a code to get into service mode, but you should read over the service manual before you attempt to enter the service mode and change any settings. You can really mess up your set very easily. You can get the service manual at the link provided below, but you will need to register with the site to get it.
Link to site
Posted on Mar 13, 2008
  • Barry Gardner
    Barry Gardner Mar 15, 2008
    If the corner correction settings are not doing what you need it may be
    that you have to rotate the yoke on the back of the tube. There are two
    clamps on the yoke, one for the yoke itself and one for the purity
    magnets (page 10 in manual). Loosen both clamps but don't move the
    purity rings, you only want to rotate the yoke to align the picture.
    The yoke may be glued on so be careful not to crack it. Twisting back
    and forth may help crack it loose so you can turn it. Don't push it in
    or out as this will change the purity, just rotate it.
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
My SAMSUNG PPM42M6H screen has horizontal grainy lines at the top of screen measuring about 7 inches and from right to left. Lower half seems OK. What should be done or replaced?
Check the ribbon cables in side the TV that connect to the panel. They are the left side looking at the back. Make sure they are all seated propporly. If that does not fix, then your Upper Y Buffer board needs to be replaced.
Apr 10, 2012 | Samsung PPM42M6H 42 in. Plasma TV
4gb pmp350-4 mp3 player touch screen. Screen is back only can see a shadow images of icons try to reset screen is still very dark. can this be fix?
From the main menu of you mp3 player touch the lower right corner of the screen, then touch the lower left side of the screen, then press the lower middle section of the screen. Then press the lower left side of the screen again and then the lower middle screen. Then press the lower left side of the screen until the screen brightens. From there you should see your screen to further assist yourself...Your welcome(:
Dec 27, 2010 | Polaroid Juke Jam PDP602 MP3 Player
Blue Noise, left side of TV
I have the same problem -- had a Best Buy technician out 4 times so far, replaced 2 parts, adjusted the voltage, etc., but still have the same problem -- looks like there may be no solution other than replacing the TV, which is an expensive proposition considering that mine is about 18 months old.
Jun 12, 2008 | Samsung HP-S4253 Television
Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Jun 10, 2008 | Samsung HP-S4253 Television
KDF 42 Sony Wega
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 08, 2007 | Sony KP-57WS500 57" Rear Projection...
Pioneer SD-T50W1
Take the lower speaker grill cover in front off.Remove screws holding sreen frame on. slide screens to side to access cavity.Ask a pro or go slow!!be gentle and observant. remove webs with rag or feather duster.DO NOT spray any liquid.Dust RGB lens caps with soft cloth.Re-assemble.
Sep 17, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
JVC AV-24F702 24" TV Logo
78 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
